It is currently Fri Mar 29, 2024 3:10 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Pilot Engine CSI -
PostPosted: Mon Apr 09, 2012 6:38 pm
davidafco wrote:
On the water pump rebuild is there anything special to getting the new mechanical seal in? I know the old 1 was a bitch to get out and had what looked like lock tite on it. The new seal has the blue stuff as well. Just asking before I screw up a $45 seal.
Nope I clean off all the old sealer crap then install the new one using a socket that fits the seal OD perfectly then tap it in with a hammer, the stuff on the OD of the seal is the factory sealer they apply make sure no grease or oil is on the parts before you assemble.
Also make sure you install the black rubber seal the right way you want the spring side facing the inside of the balancer case not facing the water pump, your trying to keep the oil inside the balancer case just like the seal behind the recoil starter.
PostPosted: Mon Apr 09, 2012 7:07 pm
Got it,, thanks
PostPosted: Sat May 12, 2012 6:06 pm
Any updates Hoser on the Engine?
PostPosted: Sun Sep 30, 2012 10:14 am
Hoser any updates on this Engine?
PostPosted: Mon Jun 10, 2013 10:26 am
Engine installed in TurboTexas pilot over the weekend.
Registered users: Bing [Bot], canadian oddy, Google [Bot]
