It is currently Wed May 14, 2025 8:51 am
 Post subject: stock carb info
PostPosted: Sat Aug 25, 2012 3:23 pm
What's the stock jets that came in a Oem Fl350? Took mine out today for the first time since swapping the Oem carb on. It doesn't want to rev out like it use to or seem to have a lot of power. I beileve the jets are completely off in it.
 Post subject: Re: stock carb info
PostPosted: Sat Sep 01, 2012 1:12 pm
The manual has a page on the jetting process on page 14-4 this lists the jet sizes for the STOCK Fl350 carb
http://g2buggy.g2-innovations.com/gentech/manuals.htm
If you have modifications to your Engine of any kind, you will need to compensate for that.
PostPosted: Sat Sep 01, 2012 1:42 pm
Just curious what carb you were running before and why did you swap it?
You serviced the carb you just installed?
PostPosted: Tue Sep 04, 2012 8:58 pm
Thanks Rand!
Hoser,
It had a 34mm PE carb on it but it was such a pain to tune because of the location of the needles. The choke was hard to gt to, and it just never ran right with it. I swapped the stock carb back on it when I did the top end. This has been the first time I actually taken it out for a rip. Otherwise it was mainly putt around the yard to move it.
