The other day I went to hit my starter button and it had no power.. The next thing I know I see white whisps of smoke rising from the stator wires.
After inspection I realized my
motor ((
Internal Combustion Engine ? )) grounding was inadequate. I had only grounded the motor (( Internal Combustion Engine ? )) with a 10-12 Gauage wire. I had grounded the main negative battery terminal to the frame instead of in front of the balancer as I saw on Randy J.'s odyssey today. (Had no idea?) Over time, each time I hit the starter button It heated up my little ground wire until I let off. Many cycles of this later and It finally cooked off and broke. After my shoddy ground wire was severed, the next time I hit the starter, The juice from the battery had to find an alternate path. It chose the wires coming from the stator. So today I began my CSI, and didnt take enough pictures.
The ground wire on the stator was badly damaged, luckily and theoretically, maybe the stator would not take damage from this as the current probably didn't travel through the stator components itself, but instead chose the ground wire that comes directly off of it. Either way, the stator OHM is within spec. at 120 OHMS.
What I am trying to find out is... if the full power of the battery is applied to an ungrounded motor (( Internal Combustion Engine ? )), and it is forced to seek its own grounds, what components are probably screwed? I do not have spark. My Stator ohms out fine but my
CDI (Capacitor Discharge Ignition), coil, and Regulator do not ohm out properly. I am doing all my testing with the battery disconnected. The grounds that attach to the "component rack" are in tact and continuous. Is it plausable the CDI (Capacitor Discharge Ignition), Reg, and Coil are toast?
