It is currently Wed May 14, 2025 3:26 pm
 Post subject: No Low rpm power
PostPosted: Sat May 17, 2014 8:10 pm
hey guys its been a while,
I've been driving around for a week and I have come across a weird problem. If I drive for a little bit and then stop, let it idle, and try to take off again, it cant get past 1/4 rpm as if the choke were on. But as soon as I get it past that point it gets all its power back and no problems. I've been adjusting the idle screw and its fine the way it is so i have no clue whats going on. any ideas?
 Post subject: Re: No Low rpm power
PostPosted: Sat May 17, 2014 10:30 pm
plugged pilot jet ?? Air screw curcuit plugged ??
PostPosted: Sun May 18, 2014 8:03 am
Try pulling the choke does it make it better or worse? If its better your starving for fuel if its worse your getting too much fuel. :-)
PostPosted: Sun May 18, 2014 8:37 am
Pulled the choke and it got better so its starving. I think the causeof this is I lost my fuel valve so the fuel pump system isn't working correctly. Anyone have one lying around by chance?
PostPosted: Sun May 18, 2014 11:18 am
Explain fuel valve ??
Do u mean fuel T or the valve on tank?
PostPosted: Sun May 18, 2014 1:49 pm
don't rule out dirt blocking or restricting the flow of your pilot jet.
