It is currently Wed May 14, 2025 1:55 am
 Post subject: fl350 wont start
PostPosted: Tue Sep 29, 2015 6:03 pm
Ran fine yesterday, pullstart rope hanging out so i fixed that and went ahead and installed a Y head since it had the crappy straight fin 1 still on it. And then put all back together with new head gasket and wont start now, getting gas n has spark but wont start
 Post subject: Re: fl350 wont start
PostPosted: Tue Sep 29, 2015 6:27 pm
Sounds like you need to check compression.
PostPosted: Tue Sep 29, 2015 7:47 pm
Welcome new guy.
And check fuel pump flow as well. (4.5oz in ten seconds) approx
If you got spark it's gota be fuel so check the carb also.
PostPosted: Tue Sep 29, 2015 8:10 pm
Here is where im at, i have spark, even with priming will not fire. Rode fine yesterday b4 repairs. I have swapped coil, CDI (Capacitor Discharge Ignition), stator, checked flywheel key. I figured like always compression will fade. For piece of mind im having compression checked tomorrow.
PostPosted: Tue Sep 29, 2015 8:44 pm
Tap intake with some starting fluid to eliminate fuel problem.
