It is currently Wed May 14, 2025 2:50 am
PostPosted: Fri May 01, 2020 10:57 am
I have a Honda Odyssey motor (( Internal Combustion Engine ? )) I believe it's an FL250 possibly 350 but anyways I have just the motor (( Internal Combustion Engine ? )) and I'm putting the motor (( Internal Combustion Engine ? )) in a go-kart and I need help with the four wires that are coming out from the motor (( Internal Combustion Engine ? )) I had the motor (( Internal Combustion Engine ? )) run a while ago but I just cannot remember what's missing. I hope please help
PostPosted: Fri May 01, 2020 1:05 pm
Welcome new guy.
This site is very slow sometimes so you have to be patient for replies. Many old members have left.
You will also notice that when you type "motur" the site has an auto correct and then (( Internal Combustion Engine ? )) comes up. It's a pain in the azz thing that happens because the site admin doesn't like incorrect use of that term LOL. Funny thing is that when you talk about and electrical "motur" it will do the same thing LOL.
Anyways you will have to post a picture of your Engine so we can help. A wire is a wire and the two engines are different even though color codes are common.
You can get a free PDF manual of the FL250 or FL350 here: https://oddatv.com/fl250-fl350-factory-manuals/
Below is a pdf I have attached that you can download -- it's a color diagram of the FL350 electrical.
wiring schematic.pdf [86.85 KiB]
Downloaded 222 times
