Muddbogger FL350 LQ Cylinder CSI http://www.pilotodyssey.com/PO/viewtopic.php?f=26&t=3850 |
Page 1 of 2 |
Author: | hoser [ Thu Jan 03, 2008 1:13 pm ] | ||||||
Post subject: | Muddbogger FL350 LQ Cylinder CSI | ||||||
Mudbogger sent me his old liquid cooled FL350 cylinder for inspection. After opening up the box and removing I felt something lose in the palm of my hand, its a chunk of the cylinder skirt. No damage to the box it came in .
Author: | hoser [ Thu Jan 03, 2008 1:18 pm ] | ||||
Post subject: | |||||
Here is where the cylinder skirt is broke. I don't think the sleeve can be replaced since part of its broken off you would have to send to someone like LA Sleeve and ask, usually they over bore the stock sleeve and press in a new liner they usually don't fully remove a cast in liner like on this cylinder.
Author: | hoser [ Thu Jan 03, 2008 1:21 pm ] | |||
The tube that sticks out of the cylinder for the coolant hose is also bent.
Author: | hoser [ Thu Jan 03, 2008 1:24 pm ] | |||||||||
Post subject: | ||||||||||
Some pics of the bore you can see uneven wear.
Author: | hoser [ Thu Jan 03, 2008 1:25 pm ] | ||||
Some pics of the water jacket they welded on, looks like nice work to me.
Author: | hoser [ Thu Jan 03, 2008 1:26 pm ] | |||
Pics of the stock head that was converted to LQ by cutting off the old fins and welding up a water jacket.
Author: | hoser [ Thu Jan 03, 2008 1:30 pm ] | ||
Post subject: | |||
Its hard to see in the pic but that's a .004 feeler gauge between the cylinder wall and piston, I have not taken any other measurements other than this quick and dirty method of testing http://pilotodyssey.com/PO/viewtopic.php?t=3115 I cant get a .005 feeler gauge to fit, gut feeling guess is the clearance is .0045, I didnt waste my time taking precise measurements since the cylinder is broke if you want exact measurements let me know.
Author: | hoser [ Thu Jan 03, 2008 1:34 pm ] | |||||||
The piston actually looks good, very low hours, it could be reused as is, you also could send it out for skirt coating also. Their is some slight scuffing on the skirt, the coating would take care of that, the piston was never over heated the wrist pin floats in and out easily, you can tell Hare had it jetting with his signature super FAT jetting heh Its hard to get good pics of the piston inside but their pics make it look 100x worst than it is .
Author: | hoser [ Thu Jan 03, 2008 1:36 pm ] | |||
OD of the piston skirt
Author: | hoser [ Thu Jan 03, 2008 1:37 pm ] | |||
A real quick and dirty measurment of the cylinder ID
Author: | hoser [ Thu Jan 03, 2008 1:49 pm ] | ||
Post subject: | |||
Looking at the wiseco piston chart this cylinder was on second bore. Shame its broke it had 3 bores left..
Author: | mudbogger [ Thu Jan 03, 2008 6:20 pm ] |
Post subject: | |
I am so mad I cannot even reply back to this thread-MY APOLOGIES. I sent the motor (( Internal Combustion Engine ? )) to Triple EEE complete, so unless it was broken in the motor (( Internal Combustion Engine ? )), it broke there or was damged between there and your place, but the box seems to have no damage but who knows? The bore as told to me was not straight and needed 2 -3 bores at least to get it straight and by that time it would be on the last bore. The piston wall clearance as well was off from what I was told, I remember it to be over 50-close I guess- They did HOWEVER say the piston was reuseable- |
Author: | Pilotman [ Thu Jan 03, 2008 6:39 pm ] |
Post subject: | Shipped UPS |
If you shipped it UPS and had the extra insurance on it, you may still be able to file a claim for damages. They have a habit of dropping boxes from heights (aka loading docks) to see what they can break. It couldn't hurt to at least open a claim and try to recover at least the $100 they cover without insurance. Sorry for your loss.... Pilotman |
Author: | mudbogger [ Thu Jan 03, 2008 6:48 pm ] |
Post subject: | Re: Shipped UPS |
Pilotman wrote: If you shipped it UPS and had the extra insurance on it, you may still be able to file a claim for damages.
They have a habit of dropping boxes from heights (aka loading docks) to see what they can break. It couldn't hurt to at least open a claim and try to recover at least the $100 they cover without insurance. Sorry for your loss.... Pilotman Hi Pman-wish you were here in NJ I checked with Sara and they did not insure the shipment back-just my luck huh? I also told her about the damage and of coasre it wasn't them-figured that 1 huh? |
Author: | mudbogger [ Fri Mar 14, 2008 6:28 pm ] |
Post subject: | |
Hoser-I contacted LAsleeve and they say I can send it to them for resleeving-the skirt issue was discussed at great length and I described the damage in detail-they still say it can be done.You still have it with Piston right? |
Author: | mudbogger [ Tue Aug 05, 2008 6:05 pm ] |
Post subject: | |
Hoser-you still have this complete set-up right?I was told by LA SLEEVE they can indeed put a new sleeve in it-dunno but I am up to trying it-can you ship the jug to them for me by chance?Also should we ship with the piston or no?I'll of coarse send you the shipping costs immed. |
Author: | mudbogger [ Thu Aug 07, 2008 3:50 pm ] |
Post subject: | |
hoser-LA SLEEVE said to measure the OD of the skirt-if it measures 3.385 then it can resleeved with the damage pictured.The tech says to measure it at the very top of the skirt-the broken piece does not need to be shipped as it will not be needed.They will replace it totally. |
Author: | hoser [ Sun Aug 10, 2008 10:09 am ] |
Post subject: | |
Mudbogger wrote: hoser-LA SLEEVE said to measure the OD of the skirt-if it measures 3.385 then it can resleeved with the damage pictured.The tech says to measure it at the very top of the skirt-the broken piece does not need to be shipped as it will not be needed.They will replace it totally.
I measured the OD of the skirt at the bottom of the cylinder and it measures 86.46 mm or 3.403 give them a call and see if its a go or no go, since its only .009 on each side I would think they could leave .009 of the old skirt their and install the new? |
Author: | mudbogger [ Sun Aug 10, 2008 12:25 pm ] |
Post subject: | |
hoser wrote: Mudbogger wrote: hoser-LA SLEEVE said to measure the OD of the skirt-if it measures 3.385 then it can resleeved with the damage pictured.The tech says to measure it at the very top of the skirt-the broken piece does not need to be shipped as it will not be needed.They will replace it totally. I measured the OD of the skirt at the bottom of the cylinder and it measures 86.46 mm or 3.403 give them a call and see if its a go or no go, since its only .009 on each side I would think they could leave .009 of the old skirt their and install the new? Thanks Hoser the OD of the new sleeve is 3.475 according to the tech-he says ship it they can do it according to the measurements given by you. |
Author: | hoser [ Sun Aug 10, 2008 12:36 pm ] |
Post subject: | |
Mudbogger wrote: hoser wrote: Mudbogger wrote: hoser-LA SLEEVE said to measure the OD of the skirt-if it measures 3.385 then it can resleeved with the damage pictured.The tech says to measure it at the very top of the skirt-the broken piece does not need to be shipped as it will not be needed.They will replace it totally. I measured the OD of the skirt at the bottom of the cylinder and it measures 86.46 mm or 3.403 give them a call and see if its a go or no go, since its only .009 on each side I would think they could leave .009 of the old skirt their and install the new? Thanks Hoser the OD of the new sleeve is 3.475 according to the tech-he says ship it they can do it according to the measurements given by you. Have an address and info to ship to? |
Author: | mudbogger [ Sun Aug 10, 2008 2:47 pm ] |
Post subject: | |
Yup- LA Sleeve Cylinder Depart. 12051 Rivera Rd Santa Fe Springs,CA 90670 Thanks Hoser- |
Author: | hoser [ Tue Aug 12, 2008 5:42 pm ] |
Post subject: | |
Mudbogger wrote: Yup-
LA Sleeve Cylinder Depart. 12051 Rivera Rd Santa Fe Springs,CA 90670 Thanks Hoser- Shipped to LA sleeve today will probably take a week to get their. |
Author: | hoser [ Mon Aug 18, 2008 6:58 pm ] |
Post subject: | |
I removed the studs from the cylinder and shipped it to LA sleeve per our conversation in the chat . |
Author: | mudbogger [ Mon Aug 18, 2008 10:26 pm ] |
Post subject: | |
hoser wrote: I removed the studs from the cylinder and shipped it to LA sleeve per our conversation in the chat .
I will call them tomorrow-did you ship today or on the 12th? |
Author: | hoser [ Tue Aug 19, 2008 8:28 am ] |
Post subject: | |
Mudbogger wrote: hoser wrote: I removed the studs from the cylinder and shipped it to LA sleeve per our conversation in the chat . I will call them tomorrow-did you ship today or on the 12th? I shipped it last week on the day I told you (I forget exactly) I just wanted to up date this post heh |
