dremmick wrote:
sorry i meant the idle screw! thanks for you help
If cracking the throttle just slightly will keep it running try to turn the air screw out when it get to 2-1/2 turns out from full in your probably wasting your time, you might be way to rich and it just needs more air with the fuel your giving it.
If this don't help try removing the restrictor in your Tee thing maybe its trying to force too much gas in the carb and the float cant react fast enough?
How are the
Engine mounts does the Engine shake really bad? I have seen broken Engine mounts allow the Engine to shake so much it upsets the float in the carb makes them run all funky.
