It is currently Mon May 19, 2025 11:34 am
PostPosted: Sat Apr 02, 2011 8:07 am
Adnoh, an educated guess is all I want or can ask for suggeted octane. don't worry about the timing, this Briggs Engine has mechanical adjustable timing and the MSD timing box too. that's a whole other ball of wax to figure out later, just going to leave it as is for now. More info to follow soon, need anything else too, let me know.
stock stroke....68mm
big bore....87.00mm Wiesco
lightened crank
piston skirt length...76.25mm
piston window port(intake side)...1.50" X .25"
exhaust spigot...51mm ID
base spacer plate...5.60mm
sleeve thickness...2.79mm
head info....twin plug NKG B9ES
inner dome width...69.73mm
outer dome width...87.00mm
inner dome volume...30ml/cc
outer dome volume...12ml/cc
total volume...42cc
squish... .0525"-.054"
squish angles...????
piston angles...????
The compression test yielded about 137-140 lbs which suprised me. I was expecting much higher. I also expected a lower CC dome. I still need to figure ring end gap and piston wall clearance(no feeler gages with me). Fresh hone and new rings might help compression, or just need to run it a bit to get them re-seated????
File comment: base plate w/ spray copper gasket
File comment: port windows BDC
26 Mar 11 003 (Large).jpg [70.19 KiB]
Downloaded 22 times
File comment: Engine side view
File comment: TDC (Top Dead Center)
File comment: Compression 137-140
28 Mar 11 014 (Large).jpg [81.37 KiB]
Downloaded 22 times
PostPosted: Sat Apr 02, 2011 8:15 am
more pics...
I added soy sauce to water for my CC measurements, so if you are smelling/thinking chineese food when riding with me, that's why! LMAO
File comment: squish
28 Mar 11 017 (Large).jpg [39.42 KiB]
Downloaded 21 times
File comment: inner dome 30cc 69.73MM
File comment: outer dome 12CC more for a total of 42CC 87mm
28 Mar 11 020 (Large).jpg [72.81 KiB]
Downloaded 21 times
File comment: side view
28 Mar 11 021 (Large).jpg [48.54 KiB]
Downloaded 21 times
File comment: My hi-tech CC dispenser, ML are equal to CC, if you didnt know
28 Mar 11 022 (Large).jpg [73.66 KiB]
Downloaded 21 times
