It is currently Mon May 19, 2025 4:43 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2  Next
PostPosted: Sun Jan 30, 2011 1:50 pm
:shock: Very unique looking to say the least. I was told its capable of running in the 9K range and makes 90+HP on 110 race fuel.
29 Jan 2011 005 (Large).jpg [79.23 KiB]
Downloaded 176 times
29 Jan 2011 006 (Large).jpg [78.35 KiB]
PostPosted: Sun Jan 30, 2011 1:55 pm
more pics
PostPosted: Sun Jan 30, 2011 2:03 pm
more...
PostPosted: Sun Jan 30, 2011 2:08 pm
last of the external pics...
29 Jan 2011 025 (Large).jpg [73.52 KiB]
Downloaded 170 times
PostPosted: Sun Jan 30, 2011 2:14 pm
The Beastie's pipe...
29 Jan 2011 026 (Large).jpg [81.24 KiB]
Downloaded 169 times
PostPosted: Sun Jan 30, 2011 2:25 pm
Take it apart I want to see whats inside lol, looks like the silicone homo blew his gob of silicone all over that Engine too.
PostPosted: Sun Jan 30, 2011 2:29 pm
LMAO!!! Ya, I don't know who bought Bobs old cars but was told they ran em for a couple of years then sold em to Moskito. Moskito, pulled the engines and put in 4 strokes. that's where I got all the stuff. I ASSUME the Lords of the RTV were the second owners. :-)
PostPosted: Sun Jan 30, 2011 2:58 pm
Yeah I would not think anybody in the Briggs camp would use silicone to assemble the engines like that.
Cant wait to see these run I would be installing this one in the 350 you have the 410 in, if I had a Pilot I would be looking at making a Engine mount adapter so I could install it in a Pilot.
After drooling over the pics again... the belt driven water pump looks complicated and expensive I wonder if they went the belt driven route so they had variable coolant flow, low flow at low rpm and higher flow at higher RPM's, I wonder if the electric pumps were flowing too much at the wrong times?
Also see the adjustable ignition timing plate?
PostPosted: Sun Jan 30, 2011 3:12 pm
Thinking the exact thing as a posibility, the Leckich 420 machine already has works shocks all the way around. Hate to tear it down all the way. I may put the other Bob Briggs Engine in place of the Leckich for now. It is supposed to be 80-85HP. I will get another thread started on it. It also runs the same water pump system, also seen spare parts for them in a totetoo. I bought a couple more 350 frames to build on(a-arms, etc) so have 6 frames to chose from. Really need some "Baz"weather right now so I can get started. Kinda tough in neg temps with waist deep snow...depressing.
PostPosted: Sun Jan 30, 2011 3:17 pm
I would like to see the inside of that water pump too, you can see signs that the silicone homo was inside it at one time also.
I bet inside you will find a impeller off a something OEM like a Pilot water pump or maybe some motorcycle, home made housing for sure, shaft might even be home made?
Main interest is the seal they used guess it could be something OEM also.
PostPosted: Sun Jan 30, 2011 3:28 pm
LMAO, your killing me Hoser..."the silicone homo"! :-) :-) :-) He is worse than the "bling homos"! lol
I did see a spare impeller on a shaft somewhere too. I will open it up..just for you! Had too many Shiners Bockslast night and the head is still rough.
Found some spare stuff...looks to be fabricated stuff to me.
29 Jan 2011 032 (Large).jpg [74.76 KiB]
Downloaded 154 times
PostPosted: Sun Jan 30, 2011 3:44 pm
I'm totally guessing ,but could they have even run an electric water pump with this electrical system?No charging system?
Could the external water pump be so they could change the drive ratio to use less HP to drive it?(not enough room in stock location to add larger pulley?)
PostPosted: Sun Jan 30, 2011 3:59 pm
Definately a possibility Bullnerd.Probably depends more on the draw of the electric pump but I would think it would be fine. Being that they didnt run a charge system, they were trying to conserve everything electrical as possible...no power in mid race would suck!
I was told that a charged battery would last them all weekend. Not sure if they used a fan on the radiator or not. I had 2 radiators with fans and 2 without(Kuda got 1 with a fan). I only have one resivour tank. I do need to find more or something that will work as a subsistute.
PostPosted: Sun Jan 30, 2011 4:32 pm
The cars these engines went into were designed to be run about 1/2 hr max fact is most of them would be lucky to finish a 1/2 race with the gas tanks they had, when Renni and Bob came to WI to race 2 of the SODA races they both were running out of gas on the last lap of a 20 min race, the difference they seen was the fact that the tracks were 2 miles per lap and they were running WOT (Wide Open Throttle) much more than on the tracks they were use to racing.
Between heats they could change the battery to a fresh charged battery.
What draws more HP a mechanical water pump or a stator supplying power to a electric pump?
1 HP = 746 watts stock charging system is how many watts? That number is the MAX watts not what its producing all the time.
My guess is they were more worried about the weight of the flywheel than the charging draw of the charging system, put this on your list of questions to ask them next time you call :-)
PostPosted: Sun Jan 30, 2011 4:38 pm
Yeah,lose the weight of a flywheel and gain an adjustable super light water pump?
PostPosted: Sun Jan 30, 2011 4:41 pm
I remember reading that they also relied on the thermal rising(don't know the excact terms used) of the water to help it flow through the rad.Maybe this alows for a slow/er turning pump?
PostPosted: Sun Jan 30, 2011 4:43 pm
Nuke -em do you need the resi if the rad is above the Engine?Didnt Kuda just go through this?The briggs had the rads very low.
PostPosted: Sun Jan 30, 2011 4:57 pm
Not sure, still gathering info on this stuff. Never been around a EEE and didnt pay much attention to radiator location in the pics. good info,thanks. Feel free to add anything else for discussion...hence the post n pictures, I am not a secret info guy, i will tell/share all info. :-)
PostPosted: Sun Jan 30, 2011 5:27 pm
From Hosers picture page-check out the last two.
http://www.pilotodyssey.com/sl3.htm
PostPosted: Sun Jan 30, 2011 5:52 pm
Every pic I have seen,they were mounted low and the res tank was mounted higher,of the briggs cars,Rennie owned 4 or 5 of them,
Bob owned 3, I think; hence the differences in the cooling systems,Bob ran his cars as light as humanly possible{from what Im told he was a lighter the better kinda guy} mech, water pumps,
Rennie ran the electric pumps.
In the early days Rennie and Bob worked close together on these cars...but had a falling out over something From what Im told..{{{all second hand info}}}}
Bullnerd,
Thanks.... I got my hands on one of the original ones along with the original heads for my 360
so Im good
PostPosted: Sun Jan 30, 2011 6:18 pm
Nuke em
Can you see the balancer gear in the dip stick hole?
PostPosted: Sun Jan 30, 2011 6:25 pm
Where is the wick?
Poofkboom!
PostPosted: Sun Jan 30, 2011 6:48 pm
Stoneman wrote:
Where is the wick?
Poofkboom!
Ya, but what a ride til then!!! :-) I have LOTS of spare parts and engines.
I will bet good money I can get some reliablity out of em too. I have had 1 piston failure in my Leckich 420/350 in 5 years and that was due to a base gasket airleak. Still running the same 88.50 bore too. The Leckich was another stadium Engine combo, just like these.
PostPosted: Sun Jan 30, 2011 6:50 pm
KUDA wrote:
Nuke em
Ya, the beastie runs the balancer setup.
PostPosted: Tue Mar 01, 2011 11:06 pm
I pulled the head and jug tonight for an inspection before putting it in a Odyssey. Glad I did. I was told this Engine was running fine when pulled, and could be dropped in and go. Not in my book! Here are a group of pictures, look em over close and tell me whats wrong...and whats right. I will tell you what caught my eye.
