It is currently Mon May 19, 2025 8:53 am
PostPosted: Sun Dec 15, 2013 4:13 pm
1989-1990 Honda FL400 FL 400 Pilot Stator $149.99
http://www.regulatorrectifier.com/catalog/1989-1990-Honda-FL400-FL-400-Pilot-Stator
The highest grade copper wire for the windings was used with a slightly reconfigured winding configuration from stock and the high magnetic conductivity of the new stator core result in vastly improved performance compared to stock.
The power range is consistent throughout the entire RPM range but it also runs much cooler than the stock stator, which drastically improves reliability. The pulsar coil is made from the finest components available as well as the grade lead wires that feature heat and chafe resistant insulation. High quality rubber seals and insulation coatings make this stator a plug in replacement superior over the OE stator.
Some Applications 2 different stators.
See if your measurements match the following:
Outer diameter:92
Inner diameter: 35
Center thickness: 18
Replaces OE #'s: 31120-HE0-003 / 31120-HE0-013 / 31120-KAF-003 / 31120-KFG-008 / 31120-KGB-611 / 31120-KGB-D11 / 31120-KGF-891 / 31120-KGF-892 / 31120-KGF-911 / 31120-KGF-912 / 31120-KPB-008 / 31120-KPB-731 / 31120-KPC-640 / 31120-KPC-D21 / 31120-KPC-D51 / 31120-KRJ-901 / 31120-KT8-003 / 31120-KT8-004 / 31120-ML0-721 / 31120-ML0-722 / 31120-MR8-415 / 31120-MV4-000 (and possibly others)
1989-1990 Honda Pilot FL400 Stator
