It is currently Sat May 18, 2024 2:34 am
PostPosted: Mon Mar 19, 2012 6:27 pm
Below is info for BOTH front bearings only one is discontinued at this time but since people usually order these in a pair I am listing both as if both are discontinued.
Note on bearings 2RS means sealed both sides.
91051-HE0-003 Bearing, Radial Ball Search for a 60/22-2RS OR a 22x44x12
A part number search returned this http://www.partsbuggy.com/wc.dll?ctwp~g ... 51-HE0-003
PRO-X has these 22x44x12 2 side sealed part number 23.6022-2RS
91053HC4-000 Bearing, Radial Ball BRG,BALL 20X42X12 if you do a search for 6004rs bearing you get the bearing that is sealed both sides, buy one that is a NAME BRAND.
Part number search returned this http://www.cmsnl.com/products/brg-ball- ... 053hc4000/
PRO-X has these 20x42x12 2 side sealed part number 23.6004-2RS
PostPosted: Tue Jun 12, 2012 7:12 pm
91053-HC4-000 BEARING (6004) http://www.powersportsplus.com/parts/de ... 4-000.html Price: $11.71
96140-63030 BEARING (6303U) http://www.powersportsplus.com/parts/de ... 63030.html Price: $7.74
PostPosted: Tue Jun 12, 2012 7:15 pm
Seals
91251-HE0-003 DUST SEAL (30X44X6) Inner seal Price: $4.11
http://www.powersportsplus.com/parts/de ... 0-003.html
91257-KA3-711 DUST SEAL (28X42X8 Outer seal Price: $5.37
http://www.powersportsplus.com/parts/de ... 3-711.html
PostPosted: Tue Feb 09, 2016 9:41 am
I'm not sure why 96140-63030 bearing is listed here for the front wheel bearings. This bearing is for the trans and will not fit the front wheel hub? Hoser may I ask for some help on this, am I missing something?
