It is currently Sun May 18, 2025 9:52 pm
PostPosted: Thu Dec 06, 2012 9:55 pm
Im selling all my extra pilot stuff and the front lt pilot. ill post pics when the sun comes back up. I have a new top end, jug head piston with only one day ride on it after break in. Then i went back to the 500. I have a 400 jug with a 500 piston,base plate and head that go with it. I have a set of beadlock wheels, the ones with the lighting bolts on the beadlocks. The beadlock is powder coated red.I have a set of rear stock wheels, the tires weak and leak a little air.I have a set of stock tires for the rear that have never been mounted. I have one front wheel and tire never been used.I have more but cant think of it right now. Ill get it all togeather and take pictures. call with q's 949 291-9418 chris (cpap) The pilot has atvr lt front with fox shocks all the way around, atvr radiator relocated,atvr nerf bars, bumper, and rear bumper. It has a really fast hoser built Engine with breakin and two trips at johnson valley and dumont. You can see it in the pics in trips section here. need it gone asap and will deal for all of it. The pilot has a speedchaser head.
PostPosted: Fri Dec 07, 2012 1:16 am
PostPosted: Fri Dec 07, 2012 1:21 am
PostPosted: Fri Dec 07, 2012 1:28 am
PostPosted: Fri Dec 07, 2012 1:34 am
PostPosted: Fri Dec 07, 2012 1:56 am
the beadlocks are sold
PostPosted: Fri Dec 07, 2012 11:04 am
quote from above "I have a set of stock tires for the rear that have never been mounted."
I pmed you on the stock rear tires.
PostPosted: Sat Dec 08, 2012 12:40 am
Sorry guys i just got home from work. Ive talked to 30 people about stuff today on my cell. Two min after i listed this steve called and bought the two rear tires and the front tire with the rim. i then sold the rear rims and bead locks but the beadlocks may still be up for grabs. I then sold the cases ,crank and starter that are in the box.
Now I think I may part the pilot out. LT front fox shocks and frame all togeather. Ill get pics. I want to gage what people will want off it
PostPosted: Sat Dec 08, 2012 12:44 am
This is the rear rim
PostPosted: Sat Dec 08, 2012 2:13 am
Have a 38mm carb?
PostPosted: Sat Dec 08, 2012 3:09 am
Brittabrat wrote:
Have a 38mm carb?
yup flat slide will need cleaning. It was running on the other pilots old motor (( Internal Combustion Engine ? )) till i bought the pwk
$50
PostPosted: Sat Dec 08, 2012 3:10 am
halorising wrote:
Brittabrat wrote:
Have a 38mm carb?
yup flat slide will need cleaning. It was running on the other pilots old motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)) till i bought the pwk
$50
you can see it on the work bench top right
PostPosted: Sat Dec 08, 2012 5:42 pm
I am interested in all 3 top ends please.Perhaps when you have a moment PM me details of them if possible?
PostPosted: Sat Dec 08, 2012 10:28 pm
the beadlocks are still for sale $400
PostPosted: Sun Dec 09, 2012 1:27 am
halorising wrote:
anybody know who the maker of the rims are?
PostPosted: Mon Dec 10, 2012 1:30 am
cases , crank and the starter are sold. stock wheels are sold. new oem tires are sold. beadlocks are sold. thank you guys. Im gonna list everything i have with pics and give you guys first shot then post it on evelbay at going rates. Peace out.
PostPosted: Tue Dec 11, 2012 12:48 pm
Hi Chris,
Do you have a Pilot pipe you're selling? Stock or aftermarket?
Brooks
PostPosted: Tue Dec 11, 2012 8:03 pm
brooks wrote:
Hi Chris,
Brooks
maby, i think im getting really close to parting it out
