It is currently Tue Apr 16, 2024 4:31 pm
PostPosted: Wed Jul 26, 2017 8:21 pm
**updated, dropped the price - just adopted and need the cash...
Selling my FL350, I got the bug and what to trade up for a fl400. Will take $1200 and consider fl400 trades. Im happy to help with shipping as well but I don't have access to a truck so I cannot transport it.
The Good
- It runs,
- Recently cleaned the carb
- Full brake system disassembly and cleaning, including master + replaced sight glass
- Repaired and repainted fenders
- Repaired floor boards
- transmission shifts and go into gear
- Front tires are 50-75%
- clutch and belt are is working order
The Bad
- It does run well. Failed the leak down test and has 105psi compression
- Front brakes still need adjustment
- No front fenders
- Front control arm bushings warn
- Gas tank cleaned but still a bit rusty, fuel tubes clogged. Petcock drain retrofit plug included
- Rear Tires are at 25%
- Pull start cover guid tube was damaged and needs repair
PostPosted: Sun Oct 15, 2017 10:45 pm
Sold
PostPosted: Mon Oct 16, 2017 7:45 pm
djscoutmaster wrote:
Sold
Send the new owner this way please.
Looks like that 350 needs viewtopic.php?f=107&t=4779
Registered users: Bing [Bot], chorizofingers, Google [Bot], liduno
