It is currently Sun May 18, 2025 10:08 am
 Post subject: brake master cylinder
PostPosted: Tue Jan 01, 2013 12:45 pm
im looking for a master cylinder for a fl350 theres one on ebay for 250 i think that kinda steep. i bought a rebuild kit but broke the lid screws and cant get the plungers out. now im stuck with kit and bad housing, can anybody help me
PostPosted: Tue Jan 01, 2013 1:12 pm
how bad are the screws broke off? i drillednout one of mine and used larger screws.
PostPosted: Tue Jan 01, 2013 2:17 pm
the screws are no big deal its the plungers. this thing has been sitting for a long time. what a nitemare. do you just pull the plungers out after the snap rings are out
PostPosted: Tue Jan 01, 2013 11:42 pm
This may help, sorta an exploded view. http://www.servicehondapsn.com/fiche_se ... veh=132723
Once you take the dust caps off, there is a snap ring in there. it takes a bit of work to get that out (or at least in my experience) since the snap ring pliers i have don't fit down in there well at all. Keep in mind, the snap ring expands out, into a notch on the case of the master cylinder itself. Once that snap ring is out, the plungers should just pull out. If you have a rebuild kit, i wouldn't be afraid to grab onto the metal ends of them with pliers or vice grips and yank em out since you don't need to re-use the seals.
PostPosted: Sun Jan 13, 2013 6:50 pm
i broke mine off to i had a stripped bolt kit i hammered the num.5 tool over it and it grabbeb it and backed it out coreykandi@aol.com if you need a pic of tool i used
