It is currently Sun May 18, 2025 11:59 pm
 Post subject: Pilot 80mm rings
PostPosted: Tue May 21, 2013 5:40 pm
I need a set for my standard size piston
 Post subject: Re: Pilot 80mm rings
PostPosted: Tue May 21, 2013 5:51 pm
80mm Odyssey rings will work too long as they are the same brand of piston, OEM to OEM wiseco to wiseco.
Your piston new or used?
PostPosted: Tue May 21, 2013 5:53 pm
It's a used one I wanna just put new rings it
Wiseco
PostPosted: Tue May 21, 2013 5:56 pm
You can buy them for $30 new from your local motorcycle shop
PostPosted: Tue May 21, 2013 6:02 pm
Did you measure the piston to cylinder clearance to make sure its not excessive?
I have yet to see a 2 cycle piston in anything that when the rings were worn out the piston was not worn out.
Too much clearance it will rock in the bore then the piston will break and do major damage to your Engine, 200.00 rebuild turns into a 2000.00 rebuild
PostPosted: Tue May 21, 2013 6:10 pm
Rocky Mtn has them, Ebay as well always has rings for sale for Wiseco. Or purchase direct from Wiseco.
