It is currently Mon May 19, 2025 4:44 pm
PostPosted: Sat Nov 02, 2013 10:16 pm
I am looking for the gaskets for the Pilot trans. I know they are in the Vesrah kit but it is currently backordered and I thought someone might have the OEM gaskets in their extra parts.
The part numbers are
21195-HE0-000
GASKET, REDUCTION CASE
21195-HE0-010
21195-HE0-P00
21198-HE0-010
GASKET, R. REDUCTION COVER
21198-HE0-000
21198-HE0-P00
061C1-HE0-000
GASKET KIT, REDUCTION
PostPosted: Sun Nov 03, 2013 12:41 am
None of these guys have them in stock?
http://www.powersportparts.net/Vesrah_C ... 177102.htm
https://www.google.com/search?q=vg1097m ... =firefox-a
PostPosted: Sun Nov 03, 2013 1:36 am
I made my own,just get the thickness correct to maintain case to case distance.
I think .5-.6mm? Measure with micrometer.
Otherwise you compromise the lateral thrust backlash.
Pair of scissors,pencil,and hole punch,easy peasy.
PostPosted: Sun Nov 03, 2013 8:16 pm
I was looking for the pilot not the 350. :-)
PostPosted: Sun Nov 03, 2013 8:18 pm
I should not say this out loud but my wife sucks at that and with my eyesight so bad who knows what it would look like if I did it.
PostPosted: Sun Nov 03, 2013 8:46 pm
PostPosted: Mon Nov 04, 2013 3:19 am
Not sure how I screwed that one up but I did here I fixed the links try again viewtopic.php?f=37&t=9707&p=121606#p121606
PostPosted: Mon Nov 04, 2013 9:12 am
http://m.ebay.com/itm/331058663706
PostPosted: Tue Nov 05, 2013 12:20 am
http://www.powersportparts.net/Vesrah_C ... 177102.htm" .".." .".." ."..
https://www.google.com/search?q=vg1097m ... =firefox-a" .".." .".." ."..
Not sure how I screwed that one up but I did here I fixed the links try again viewtopic.php?f=37&t=9707&p=121606#p121606" ."..
Thanks I did not know about HyperParts.com the place I was trying to get one from was in Canada. I will try to call them tomorrow.
PostPosted: Tue Nov 05, 2013 12:22 am
afastcar wrote:
http://m.ebay.com/itm/331058663706" ."..
I will use Athena if I cant get anything else but I have not had good luck in the past with their gaskets.
PostPosted: Tue Nov 12, 2013 9:36 pm
What kind of problems you have with Athenas, installation probs or long term issues? BTW Randy is checking on the trans gaskets :-)
PostPosted: Tue Nov 12, 2013 10:24 pm
They show them in stock
http://www.partsbuggy.com/wc.dll?ctwp~i ... 2~602-1343" .".." ."..
vesrah part number 602-1343
They have at least 5 in stock - order while you can. 866-236-4793
PostPosted: Tue Nov 12, 2013 10:35 pm
Powersport Superstore sold through Amazon always have excellent prices http://www.amazon.com/Athena-P400210850 ... B000TYNGKS
PostPosted: Wed Nov 13, 2013 1:44 am
I used to work for a shop and they always tried to save a buck on parts. I built a lot of high powered Yamaha Banshee engines. I've had quite a few vehicles came back because they had developed leaks in base and clutch gaskets on the Athena's. Plus they always stuck out just that little bit which annoys me. We ended up not using them anymore on the Banshee's at the shop and just stuck with OEM. I do not know what the fitment looks like for the Pilot gaskets from Athena but I know that I have heard other people complain. I would rather use OEM if I can but beggars cant be choosers. :)
Thanks for all of your help guys.
PostPosted: Wed Nov 13, 2013 1:53 am
I have use quite a few of the Athena's on Pilot engines they stick out more than others and the material they use is the farthest from being OEM than all the others, the material is harder and ore brittle than all others, performance wise I cant comment but time will tell if we start having more leaks or blow outs.
Cant beat OEM really kicking myself for not buying 20 OEM sets when I could still get them.
