It is currently Thu May 15, 2025 4:31 am
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: 350 PARTS FOR SALE.
PostPosted: Fri Dec 25, 2015 8:59 am
MERRY CHRISTMAS!!
I recently sold one of my properties and have a bunch of 350 parts that have been stored there I would like to sell off. The list is endless and for me to catalog it would take more time then I have.
So, If anybody is looking for any 350 items please send me a PM and I'll see if I have it for you, prices will be negotiated with each buyer If I have what you need.
Please PM ANY parts inquires, thanks.
If anybody here in the tri state area wishes to come and purchase the whole lot it can be viewed as well.
 Post subject: Re: 350 PARTS FOR SALE.
PostPosted: Sun Dec 27, 2015 12:06 am
UPDATED 4/03/2016
Have a set of brand new Progressive front shocks in the box for sale. Make offer via pm please for everything listed
Have 1 Kleem research complete used air boxes for sale.
Have air box lids from aussieduner that makes single 350 airbox a dual inlet box.
Numerous shaved stock heads I purchased years ago from afterthought motorsports.
2 tranny's without brake discs
1 set of speedchaser front and rear fender billet brackets.
Used great shape fuel cells- 1 powder coated gloss black, other stock paint.
Numerous rear suspension arms, some powder coated in gold and chrome, others stock.
Numerous rear bearing carriers. With and without bearings and seals. All used.
Numerous rear Upper arms for alignment of rear wheel.
Numerous trans to Engine mounts. Some powder coated gloss black
36mm PJ carb in good shape.
I lower case half with broken Engine mount
Flywheel and stators used.
350 cranks, used, no idea as to main bearing condition.
Starter mounts from cases to starter.
1 used frame complete been sitting outside missing bracket for battery box but complete.
Numerous steering wheels-some complete and some missing brake levers. In various conditions.
Some Rear brake calipers, most missing the e brake hardware.
Shifters, again in various states of condition, some with cables but condition of these unknown
Various aftermarket rims, some are not for a 350 but have been drilled to match bolt pattern, some in good shape metal and 190's ITP
1 POLY fuel cell, believe blue in color-brand new, good external fuel cell for roll cage mounting, complete with brackets.
1 brake disc for trans warped slightly
tie rods and ends, OEM in package.
Numerous upper and lower front Suspension arms with and without dust seals.
Roll cage head nets.
1 UPPER roll cage
Carb to airbox rubber intakes.
Stock air boxes with and without lids.
Sets of 350 bolts and nuts for suspension mounting and other hardware for a 350 in zip lock baggies sand blasted.
Used rear axles, in various states some need u joints, other do not. Pm what you need on these please.
Numerous stock front fender brackets OEM
Numerous rear fender brackets OEM.
OEM stock front and rear shocks, all used.
Roll cage tops, all used, some painted, others blasted and ready for paint
1 used front OEM stock bumper, sand blasted ready for paint.
Rear barrier carriers, sand blasted no bearings and seals.
Rear hubs, gold in color. Some still in OEM plastic
Matching ignitions and gas caps with keys, sold as pairs
Wire harnesses, uncut and cut.
Steering plastics.
Steering columns with shaft and without.
Powder coated gloss black brackets fuel cell mounts
Powder coated gloss black, Purple, and chrome rear skid plates.
Powder coated chrome complete set of brackets for a 350, everything!
OEM Honda front a arm shims, still in Honda packages.
Front brake drums.
Front backing plates, I do have complete units with brakes, etc
Powder coated red air dams, rubbers included but not restored.
OEM Honda throttle cables
OEM Honda choke cables
OEM starter, think I had Stocker starters rebuild it-in box still
PostPosted: Tue Dec 29, 2015 11:05 am
PM sent! :-)
PostPosted: Tue Dec 29, 2015 11:18 am
Pm sent
PostPosted: Thu Dec 31, 2015 7:33 pm
[more parts]UPDATED 4/03/2016
1 complete frame with upper cage, missing the battery box mounts, has been sitting outside for a year-no title.
3 fuel cells, 1 powder coated gloss black, other just stock, all clean inside, no sure if petcocks are on them.
3 skid plates, 2 powder coated gloss black, other powder coated chrome.
All brackets to install a fuel cell, powder coated gloss black and some gold.
Skid plates for underside of fuel cell.
Engine and jugs for sale. I would LOVE LOVE to sell this as a lot for discounted price pleas PM:
I am now slowly splitting these bottom ends APART to make sure THE CASES AND CRANKS ARE GOOD.
Engine #1 (red in color) is complete minus intake,reed cage,and pull starter. It has stock clutch still on it. Again no idea on hrs, bore. Again purchased for rebuild.
Engine #2 bottom end only again, missing flywheel,stator, has a weld repair on cases where Engine rubber mounts insert(have pictures if interested)
1 COMPLETE JUG with head, think it is shaved but unsure, bottom of bore measures 78.75mm(have pictures if needed and it has been re sleeved yes
List of bottom end/Engine parts which it not complete, still had several shelves of crates:
I have a complete top end off Harescrambles old ody, custom water cooled made by old school ody guy from Jersey, fresh sleeve includes piston kit never used still in box from La Sleeve-make offer!!
3 pull starters complete. some better then others
2 heads( I bought these from chucklenuts at aftershot motorspurts and they are shaved) will have to cc them to figure out how much they have been shaved exactly.
1 cylinder did not measure the bore will if needed for buyer
2 cranks still have rods and bearings on them RUNOUT IS .001 MM on them bothno idea on hrs
1 left side Engine case
3 starter brackets
1 starter gear
1 OEM Honda ART 78MM piston kit
6 clutch side cases
1 balancer with all gears needed for a bottom end with hardware
3 more balancer gears with associated hardware
1 exhaust manifoldprobably have couple more laying around
1 new 80.5 mm Wiseco piston kit complete
1 new 81mm Wiseco piston kit complete
1 new 80.5 Wiseco piston kit complete
2 Flywheels, no stators
IF YOU DON'T SEE WHAT YOU NEED LISTED PLEASE PM ME-I PROBABLY HAVE IT-AND PLEASE NO TIRE KICKERS!!
PostPosted: Thu Dec 31, 2015 7:35 pm
Added more parts, more to come, I have several items not listed as I have promised them to other clients, if they don't sell I will post them. Thanks to all for the many inquires about these parts!
PostPosted: Sun Jan 03, 2016 12:02 am
Meant to send pm
PostPosted: Sun Jan 03, 2016 7:55 pm
Just wanted to say thank you to Mudbogger. I took a ride over to his abundance of parts and all I can say is WOW!! I was completely amazed at what he has been collecting through the years. I purchased many good things myself and he is a very reasonable guy. I was very happy with the purchases. I encourage anyone on this board to contact him for parts. He has stuff that is obsolete that I have never seen up close. I may be going back next weekend for more. I'm sure many people on the board know him and know what he is about. Thank you again!!
PostPosted: Sun Jan 03, 2016 8:38 pm
Thank you very much for the kind words, and for the purchases. Pleasure to meet you and look forward to seeing you again. Enjoy those parts! :-)
PostPosted: Mon Jan 04, 2016 9:12 am
**Omitted, took care of it via email**
PostPosted: Tue Jan 05, 2016 4:43 pm
PM sent.
PostPosted: Tue Jan 05, 2016 10:50 pm
PM replied too :-)
PostPosted: Thu Jan 07, 2016 5:52 pm
Pm Sent. List may grow as I rip into the odyssey.
PostPosted: Wed Jan 13, 2016 6:05 pm
Got a big box of FL350 bottom end today. Awesome deal, easy transaction, and great parts. :-)
T H A N K Y O U !!
Dan A.
PostPosted: Wed Jan 13, 2016 7:51 pm
Thank you for the kind words and glad your happy with the parts!
PostPosted: Fri Jan 29, 2016 8:59 pm
Just got my parts Wednesday (a day before said delivery date) and I thank you for your parts to get the Ody I have running again! I will be returning in the near future to buy more parts from him, great guy great parts very reasonable!
PostPosted: Fri Jan 29, 2016 10:53 pm
Thanks for the kind words, and I am glad your happy with the parts!
PostPosted: Sun Jan 31, 2016 1:12 am
Interested in some of your parts
PostPosted: Sun Jan 31, 2016 8:08 am
Pm your needs sir, I will be more then happy to see if I have what's needed.
PostPosted: Thu Feb 18, 2016 2:31 am
Just received a package of parts from Mudbogger.
Parts were exactly as he said they were, he also went to quite a bit of effort to send them to the land down under - real nice guy!
Cheers!
PostPosted: Fri Feb 26, 2016 8:00 pm
Bought parts from from mud bogger quality parts in great shape fast shipping very pleased!! Very trustworthy and we don't know each other at all but from this sale post thanks again mud!!! Tom!
PostPosted: Wed Mar 02, 2016 4:49 pm
PM sent
PostPosted: Sat Mar 05, 2016 8:20 am
Private message replied back to thank you for your interest
PostPosted: Mon Mar 14, 2016 4:08 pm
I feel like a fat kid in the candy store! NICE!!!! Wish i could bring a trailer and load up!!!
You wouldn't have a 81.50mm piston?
PostPosted: Mon Mar 14, 2016 5:18 pm
Will look tonight for you sir!
