It is currently Sat May 17, 2025 6:56 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 12, 2012 9:22 pm
PostPosted: Tue May 15, 2012 12:42 pm
Also have ecu, harness, choke cables, roof lids, battery box holder, a crankshaft and rod assembly that i do not know the condition of, rear brake caliper assembly, rear brake perch, rear brake rotor, rear axle carriers, front drum assemblys, medal brake lines, a dissassembled master for parts or rebuild,headlights,original seat belt harness(discolored), original exhaust pieces, fender brackets, hardware, cage bars, stock front and rear rims 5/10 condition (need paint and repair). Thanks again Kevin
PostPosted: Tue May 15, 2012 7:42 pm
Got the intake manifold in the mail today. Thanks again for the deal and fast shipping! :-)
PostPosted: Tue May 15, 2012 8:15 pm
Post detail pictures of the crank please.
PostPosted: Tue May 15, 2012 8:26 pm
I see the shifters but the nobs that screw down in there are missing. Do you have the pice that screws down in to the shifter base, and you screw a nob to? The part that you lift and put it into forward? i have 2 but mine are froze up.
PostPosted: Wed May 16, 2012 1:30 pm
I had frozen ones too. Soak the screw in parts in Crc Wd 40 whatever you got. Put the nut end in a vice and tap it and soak etc. All mine loosened up after working them like that. I do have a screw in levers somewhere lol. I will look tonight and try to find them. I think someone else asked me about them too. And I'll post more detailed pics in the next couple days for ya Hoser. Thanks Kevin
PostPosted: Wed May 16, 2012 2:10 pm
i put them in some PB Blaster to soak for the week while im off at school. we will see how it helps.
PostPosted: Fri Jun 22, 2012 1:41 pm
Do you still have the fender brackets?
PostPosted: Sat Jun 23, 2012 11:24 am
I have a wedding today but I will dig out any I have left and pm the results. Thanks kevin
PostPosted: Sat Jun 23, 2012 1:54 pm
Still have the complete wiring harness if so how much?
