It is currently Sun May 18, 2025 9:16 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Wed May 22, 2013 3:33 pm
I want to see a completed conversion in detail showing the radiator, fuel tank, coolant over flow tank etc. looks like much will be forced outside the cage?
don't like that welded in blank off on the mag side that should be bolt on covers so you don't have to pull the Engine to get at the mag side for service.
Agreed, I never understood the need for the armor-plating on the mag side cage. Why not just bend a couple pieces of DOM tubing that fit around the recoil!?!? That's what I'm doing.
For $1200, that Engine and parts should be cleaned up to look / run like new with some bling!
PostPosted: Wed May 22, 2013 3:56 pm
also theres no bolts included with it at all wtf? they should come with the Engine mount bolts at least
the engines are referbished ???
PostPosted: Thu May 23, 2013 10:35 am
PM sent Joe! Just after the clutch... :-)
PostPosted: Fri May 24, 2013 8:04 am
I messaged him about what refurbished means,this was his response
HI, all my engines are completely disassembled, cleaned, verified, at the very least if everything is good i rebuild them with new gaskets,seals and rings
He did not answer question about pics of completed assembly.I cant imagine him not being aware of this thread or this forum,why he doesnt come on here I don't know
PostPosted: Fri May 24, 2013 3:56 pm
I don't care who's selling it, if someone is advertising a "refurbished Engine" for a hefty price...I want to see pics of the before & after OF THE EXACT Engine I'M BUYING, a pic of the compression gage readings, the math on the bore/pistons, and a list of what was replaced or upgraded.
Otherwise just list it as a "USED Engine."
You can pick-up a complete "used" Rotax 470, the mount, modify the pipe yourself...and prob save yourself about 50%. But, the price seems to be fine since people are buying!?!? There is always a price for convenience. ;)
PostPosted: Fri May 24, 2013 5:52 pm
For someone like me who has no welder or fabrication experience,or access to lots of used rotax engines,it looks like it would be useful.In Texas theres not a lot of snowmobiles we can pull an Engine out of :-)
PostPosted: Sat May 25, 2013 1:08 am
Joshdirtbike bought an kit from him
He said it looked new
Said it had new pistons and the cases were split as there was new silicone between them
Or an list of recits would be good too
Yes but like redskinman said if you don't live in an area where there are sleds then its an convience
I agree with D$* I picked up my 537 for $180 compression is great
All the Engine needs is new gaskets so ill have $250 into the Engine by the time it's done then I could call it referbished :-)
PostPosted: Sat May 25, 2013 11:21 pm
Ace wrote:
Not allot of sleds in Hawaii either. And he's standing behind
His "any where in the US" shipping! Even to Hawaii.
that's good
that Engine are u getting?
PostPosted: Sun May 26, 2013 8:20 pm
Heres his website
http://www.farr-offroad.com/
PostPosted: Sun May 26, 2013 9:05 pm
Ace wrote:
that's good
Looking at the 470, any opinion? 583 looks good too but have
Herd great things about the 470.
Plus I bileve it's a little smaller size wise.
Joe
i would personally go with the 470
less power to tear up the trans
PostPosted: Mon May 27, 2013 12:12 am
Ace wrote:
Any opinion on the single vs dual carb intake setup?
He is giving me the choice of either.
Joe
I would prefer single intake
Jetting would be Easyer
And so I could make an air box
PostPosted: Mon May 27, 2013 10:57 am
Joe
I went with a 38mm single on my 440 Pilot setup and a single pipe my Engine makes more power than my full modified Pilot Engine did it also makes plenty of torque, nice thing about the rotary valve Engine you can play with the intake timing set it up for more torque or more RPM, my Engine was designed to run 8700 RPM I and running about 7400 RPM peak.
In the future if you want more power they do make 44mm or is it 46mm carbs you can try or even try the dual 38mm carbs if you feel your lacking power.
Had my clutching at 8200 RPM for a short wile Engine made noticeably more power but it was all wheel spin.
PostPosted: Mon May 27, 2013 6:35 pm
Looking forward to watching your build Joe. I like lots of pics of how/why stuff.
