It is currently Sat May 17, 2025 1:16 am
PostPosted: Sun May 06, 2012 10:09 pm
i am in need of a spring for my driven clutch, somthing stiffer than stock. my fl570 seems to upshift too quick and powers out. let me know what you got or where i can find one. thanks
PostPosted: Sun May 06, 2012 11:49 pm
Randy bridgewater has a stiffer white one he sells
PostPosted: Mon May 07, 2012 8:51 am
You try adjusting your current spring?
PostPosted: Mon May 07, 2012 3:06 pm
Didnt know there was an adjustment. I had just figured my spring was starting to get weak since it seems to slowly be shifting faster and faster.
PostPosted: Mon May 07, 2012 3:36 pm
Yeah look in the service manual it shows how to adjust it.
One of the first things you do when you service the driven is to release the spring tension then you have to reset the tension after you service it, their is different locations where you can hook the spring to set the tension, I had this all documented on Pilot-Odyssey.com but since Kiowa has screwed us its gone!
If its noticeable over a short period of time I would suspect something is working easier than before perhaps something was rusted now worn back in and moving freely?
PostPosted: Mon May 07, 2012 3:50 pm
it used to be perfect, maybe slightly flast to upshift but ran great. now it seems that somthing is up. there is a big open field i was riding in this weekend with a slight incline, it would hit a certain point on the gearing that it would jist not pull the rest of the rpms. coming back down the slight grade it eventually would reach full rpms. i think the Engine is running fine, its the clutching. its not lile the enine is loading up either. plugs look good, maybe slightly rich but id rather be a bit rich than lean. its just a certain point in the range it just will no longer pull.
i don't think it would be rust, been running it for a good year with the clutch as it is. could the spring have slipped out of adjustment and backed some preload off?
