It is currently Sat May 17, 2025 1:45 am
PostPosted: Sun May 13, 2012 11:29 am
http://barrie.kijiji.ca/c-cars-vehicles ... Z379294130
Quote:
Honda Odyssey FL350 Rear Axle's
1985-87 FL350R Honda Odyssey Rear Axle and
Heavy Duty Replacement U-Joint
Ready to Install
FL350 Rear Axle $550.oo each
Replacement U-Joint $45.oo each
OR BEST OFFER
Far as I know their was only ONE replacement U joint being made that fit the FL350 axle that was TESTED and PROVEN not to break but I cant remember the details does anybody else.
Best I remember ALL of the U joints that were hollow or were "grease able" (has the holes in the joints so you can grease) has proven to break under NORMAL use.
I recall people going to a junk yard and buying USED axles off a car then removing the USED Ujoints and installing them in the FL350 axles and were having good luck with them think it was a Subaru car Justy maybe?
Anybody remember this http://www.pilotodyssey.com/rockford.htm they might have them but last I remember their U joints were weak and broke use caution.
Read this thread seems Randy at Odysalvage found some that will work viewtopic.php?f=1&t=6007&start=0
You can research FL350 axles and U joint discussion on this site https://www.google.com/search?q=style+g ... 24&bih=583
350 axle discussion https://www.google.com/search?q=style+g ... 24&bih=583
I hope people are using their heads before they buy their is shit load of U joints that will fit this application again last I knew ALL but one proven to break easily under normal riding conditions.
A broken U joint results in a broken or bent rear shock!
