It is currently Sat May 17, 2025 3:51 pm
PostPosted: Fri Aug 10, 2012 3:48 pm
Hello! New to the board and my Fl350. I have a clutch "finger,lever" missing and I'm looking for a stock clutch for parts or a good used one. Please let me know what you have. Thanks
PostPosted: Fri Aug 10, 2012 5:03 pm
Theres a new powerbloc for sale here.
PostPosted: Tue Aug 14, 2012 1:49 am
Another clutch besides the power block that works very well on the Ody is the Comet 94C. It is pretty close to the performance of the stock clutch plus it's tuneable.
I haven't had much luck trying to find parts to rebuild the stock Salsbury clutch. Usually these clutches are beat to death and the parts available are worn parts people have laying around. The issues I have seen with these clutches is that the inner plastic guides are worn out which allows the clutch to bind. The rollers also tend to bind up causing the arm to wear flat spots on the rollers. If left in this condition too long, the arms wear through the rollers causing the clutch to malfunction. You can't beat the simplicity of the Comet 94c or the power block.
PostPosted: Tue Aug 14, 2012 8:08 am
http://www.pilotodyssey.com/PO/viewtopic.php?f=2&t=4967&p=39891#p39891
I made some at one time I'm still running the same set for 5 years now made the out of tool steel and heat treated them
speed :-)
PostPosted: Tue Aug 14, 2012 11:30 pm
Well hello there Speed!
The guys were asking if you were selling all your stuff off and getting out of the Pilot Ody game. Have you made any more of these clutch replacement parts?
Glad to see you are still here, alive and kicking!
PostPosted: Wed Aug 15, 2012 8:22 am
I have not made any more of the clutch part because there was no demand
Yes I'm selling a bunch of stuff to get it off my shelf it getting in the way
I have tons of odyssey fl350 parts to start to move just need more time in the day to sort :-)
I just put that Rear 5/16 wide brake disk on the fl350 seem to run good but need to put new brake pads on first to really tell
http://www.pilotodyssey.com/PO/viewtopic.php?f=46&t=7071&hilit=disk
sorry for messing up this post :shock:
SpeedChaser :-)
PostPosted: Mon Aug 20, 2012 1:54 am
i have a atock clutch here. it was split in half and ended up cutting the inside off the crank so i just have the outer piece with the spring and stuff
