It is currently Sun May 18, 2025 7:10 am
PostPosted: Thu Sep 13, 2012 11:30 am
One of the reeds has a big piece missing. Could the one reed be replaced or does the hole unit have to be replaced? The intake manifold has the normal crack in the bottom.
-Thanks ::-:
PostPosted: Thu Sep 13, 2012 11:44 am
-Thanks ::-:
You could put new reeds on your cage. You can find replacements all over. Very easy to change. Just a few Philips screws. The intake manifold and the reed cage are 2 separate pieces. They don't need to be replaced together.
PostPosted: Thu Sep 13, 2012 12:02 pm
Fatcat wrote:
-Thanks ::-:
I've seen replacement reeds on eBay, but was unsure about what one would fit the factory setup. I know, the intake has a big crack in the bottom.
PostPosted: Thu Sep 13, 2012 12:49 pm
These will get you set up. Cant help with the intake though. I had to get a used one from eBay.
http://bit.ly/NqogXQ
PostPosted: Thu Sep 13, 2012 1:26 pm
PostPosted: Thu Sep 13, 2012 1:32 pm
Here is a nos intake.
http://www.ebay.com/itm/HONDA-FL350-FL3 ... b4&vxp=mtr
PostPosted: Thu Sep 13, 2012 7:23 pm
$130.00 is a bit more than I would like to spend. Thanks for posting it ::-:
