It is currently Sun May 18, 2025 9:06 pm
 Post subject: FL350 Works Rear Shocks
PostPosted: Thu May 09, 2013 12:33 pm
I have some 1/2" shaft works rear shocks I am thinking about selling. I recently had them rebuilt last spring, the right rear shock seems to droop 1/2" more, but I think the upper left mount may be binding which holds the other shock at an angle that isnt compatible with the swing arm geometry, which prevents the left rear from compressing under the machines natural weight. I have no way to test this either. So they may need a seal refresh from Works or something.
They will come with all the mounting hardware needed. Looking to get $350
PostPosted: Thu May 09, 2013 12:37 pm
Did you get new ones?
PostPosted: Thu May 09, 2013 12:47 pm
im thinking of getting some 5/8 with rezzies
PostPosted: Thu May 09, 2013 1:18 pm
Ok, I was worried you were doin a Fatcat and partin her out... LOL
PostPosted: Thu May 09, 2013 6:21 pm
Are they bent ? How much do you weigh ? I know that they are set up for riders weight right, did you have em set up for youre weight . Let me know
I am interested.
First dibbs. lol
PostPosted: Thu May 09, 2013 9:07 pm
I am interested.
First dibbs. lol
The guy from works claims due to the weight distribution of the machine, rider weight is not a factor. I am 140lbs wet, and he claims they are good anywhere from dry machine to 250lb rider. Although I have heard numerous people claiming different rider weights on their rear shocks. They are not bent, shafts straight.
PostPosted: Thu May 09, 2013 9:08 pm
140# wet really? I shit bigger than you! LMAO
PostPosted: Thu May 09, 2013 9:34 pm
Too bad you shit rainbows you homo
PostPosted: Fri May 10, 2013 1:10 am
Out weighing you by 100 pounds I can definitely tell you rider weight make a big difference!
I can bottom out my shocks under a heavy G load however they don't bottom when I jump.
The shocks should be configured for your weight.
PostPosted: Fri May 10, 2013 11:11 pm
Cant we all Just be friends?
PostPosted: Sat May 11, 2013 9:19 am
I am interested.
First dibbs. lol
that's a 100% flip flop from years ago, they always wanted to know the rider weight even told you to put on your riding gear get on the scale not to guess, this is probably the jackass that setup the Pilot shocks that really sucked if you used the WORKS settings think lightspeed had to send his back 3 times before they got them close.
PostPosted: Sun May 12, 2013 4:39 pm
Sold!
Registered users: Bing [Bot], canadian oddy, Garemie, Google [Bot], Lanix, Q
