It is currently Mon May 19, 2025 5:46 am
PostPosted: Sat May 11, 2013 5:42 am
WANTED EITHER UNCUT KEY FOR FL350 or barrel and key to it :::also any one no wear to read the key cut number
PostPosted: Sat May 11, 2013 7:12 am
You can still buy the key new, same as crf80 key pn 35121-HF1-881 you just have to figure out if it's type 1 or type 2
PostPosted: Sat May 11, 2013 7:20 am
The key cut number is on the side of the ignition switch. You need to remove it and if I remember correctly there is a outside sleeve around the ignition which slides off and the number is somewhere on the side. Very small print, take this number to dealer or someone who cuts honda keys and your good.
PostPosted: Sat May 11, 2013 1:31 pm
I have an ignition and key if you need one.
PostPosted: Sun May 12, 2013 12:51 am
What are u asking for them and will u ship to australia
PostPosted: Sun May 12, 2013 12:53 am
Thanks for your help much appreciated
PostPosted: Sun May 12, 2013 12:57 am
Can u email me to shannon001@live.com.au price and if shipping is ok
