It is currently Sat May 17, 2025 12:51 pm
PostPosted: Fri Apr 04, 2014 1:50 pm
Hi Guys, Does anyone here know where i can get a set of post 2005 solid axles for a 660 turbo Engine Formula cross, or should i just have some made?
Cheers
PostPosted: Fri Apr 04, 2014 10:37 pm
G'Day Dave,who's DraK?Did you buy DD's T660?
Why was'nt I told Herb? :-)
PostPosted: Sat Apr 05, 2014 6:53 am
Lol, Hi Baz, No i haven't added to the collection, I'm not really into 4 strokes.
I am going to modify one of the Draks i already have. Just playing around at the moment, i don't want to raise the roll center but unless i lower the transmission i can't see a way around that.
I measured a Tiger, I have one in my garage at the moment and they also have about 50mm plunge per side and you guessed it the axle to rear arm link is almost the same as a Formula Cross.
I have found that Alain rarely does anything without reason, it seems the reason he used the plunging axles set up was to keep the roll center low.
