It is currently Sun May 18, 2025 12:27 pm
PostPosted: Fri May 31, 2013 2:10 pm
I bought this Pilot as a back-up and parts machine should I ever need to "borrow" a part. But, since I have 4 Pilots...I don't really NEED this one..but, then again, its hard to part with any Pilot. Thought about tearing it down and just storing the parts, but garage it too full.
This Pilot came from North Carolina and was a part of a team of flat track racers. It runs really strong, fires right up and has a really nice ride. Everything seems to funciton properly and is in really good mechanical shape. The Engine has good compression. Stock set-up, shocks, carb, pipe, clutch, etc. Alum wheels all around..but are alittle beat up, fronts are better than rear. Rear tires are shot. Front tires are actually in very good condition - Pure Sports Bandits
Plastics are all stiched back together, seat has a tear. Lower frame seems straight. Since this Pilot has been ridden mostly on flat tracks and no jumping..there doen't appear to be any frame stress cracks. Roll cage has a bend. It does have a plexiglass hood on it.
I havent been through it completely, but have ridden it several times it runs and drives really good. I'll be happy to provide any other information. Thanks!
UPDATED Pictures. Got some time to take it outside and take more shots. Forgot to mention that it has some nicely made rubber mud/water guards on each side of the seat. It helps to keep the dirt off. I fired it up when I had it outside, it ran good and doesn't seem to have any mechanical issues. Let me know if you have questions. thanks!
PostPosted: Fri May 31, 2013 3:04 pm
Sure wish you were closer!
PostPosted: Fri May 31, 2013 3:06 pm
PostPosted: Fri May 31, 2013 8:06 pm
gosh I mean I really could! I really could but do I really need to?
PostPosted: Fri May 31, 2013 8:25 pm
it looks bent
PostPosted: Fri May 31, 2013 8:27 pm
LOL!
Dave-Co wrote:
it looks bent
I think he says its bent.
PostPosted: Sat Jun 01, 2013 1:35 pm
na you don't :-)
PostPosted: Sat Jun 01, 2013 1:46 pm
Your are right i got too many thanks!
PostPosted: Wed Jun 26, 2013 7:16 pm
Bump - added new pics to the orignial post. Fired it up this weekend, ran good. Didn't see any oil leaks. thanks for looking.
PostPosted: Wed Jun 26, 2013 8:54 pm
Check your PM'S sir PLEASE. :-)
PostPosted: Sat Aug 17, 2013 9:19 pm
Thanks Throttle, good to speak with you sir! :-)
PostPosted: Sun Aug 18, 2013 11:12 am
PILOT IS SOLD. Thank you PO.com!
