It is currently Sat May 17, 2025 7:00 am
 Post subject: pilot fl400 parts
PostPosted: Fri Jan 03, 2014 8:16 am
hi all,
im a new member of the forum but have browsed it for years, Ive had a few pilots and loved them all!, these days ive just the one left and quite a few new oem parts that I amassed over the years.
anyway due to not using my pilot for the last ten years!! (I did the maths on when I last used it over Christmas, and this has made me realise it is time I let it go!).
just thought id try you guys on here that appreciate how good they really are before the dreaded auction site!
anyway, I have a 90 pilot that I want to let go, but probably the stuff that's of more interest on here are the parts, I am going to go through them and ill list them on here to see if anyone wants them over the next couple of weeks, there are quite a few of no longer available parts (I believe) for example I have a new barrel and head, full set of new plastics, new oem seat, a pair of new oem driveshafts, new oem front shocks, full set of douglas alloy rims, and lots of other smaller bits and pieces (probably around £6000 worth of stuff total), basically I bought lots of parts that would help me make a "like new" pilot, but I doubt ill ever get to it so its time to free up the space in my garage.
anyway much as I hate people who do the "just testing the water" thing, that's exactly what im doing, if I can get enough interest and sell off the bigger parts at decent enough money then ill get rid of the lot.
if there are any off you interested in the things ive mentioned please feel free to drop me a message, or indeed anything in particular you have been looking for I may have one!
p.s, im based in the uk, that said, the vast majority of the parts I bought came from the USA originally, so technically any import duty shouldn't be applicable as they have had the duty paid already.
my telephone number is 07872117433 if that is an easier way to contact me
many thanks, chris hill
 Post subject: Re: pilot fl400 parts
PostPosted: Fri Jan 03, 2014 2:27 pm
I'm interested in the plastics. shipping to the US may be killer though
PostPosted: Wed Jan 08, 2014 12:13 am
By chance do you have the parking brake springs?
PostPosted: Wed Jan 08, 2014 7:50 am
hi, if you mean the two that are located at the rear caliper, then yes I do, however at the minute there is a person that is possibly interested in buying everything I have and this person obviously has to have first refusal on everything. then there is another person who has expressed an interest in the majority of the parts (he has asked for the two spings you mention in his list), and he must take second refusal.
if we cant come to a deal, which is very possible as being from the uk I have had to pay much more than you lucky folk in the USA have had to pay which consequently makes my prices expensive to USA buyers straight away.
anyway, if no deals are made they are available to you thirdly by all means.
to give you an idea of the nos Honda parts I have here is the list, looking from left to right it is the quantity, then part number, then description, then uk Honda list price, then the list price multiplied by the quantity just to make totalling easier,
1 x 19033 he0 000za, rad cowell, £90.50, n/a, £90.50
2 x 80202 he0 670za, center console face panel, £103.00, n/a, £206.00
3 x 80201 he0 000za, steering column cover, £53.06, n/a, £159.48
1 x 53121 he0 003, das/steering light panel, £39.04, n/a, £39.04
6 x 52395 he0 003, ball joint r,r, upper, £39.87, n/a, £239.22
3 x 80203 he0 6707a, glove box lid assy, £37.80, n/a, £113.40
6 x 88110 he0 013, mirror assy, £65.62, n/a, £393.72
4 x 43341 602 003, rear brake piston cup, £3.74, a, £14.96
5 x 45131 ma3 006, rear brake pin bolt, £7.48, a, £37.40
2 x 45317 634 013, screw adjuster r, £7.06, n/a, £14.12
2 x 45337 634 013, screw adjuster l, £7.06, a, £14.12
2 x 45336 vm0 003, nut adjuster l, £3.32, a, £6.64
2 x 45316 vm0 003, nut adjuster r, £3.32, a, £6.64
2 x 45530 ha8 771, master cyl repair set, £29.08, a, £58.16
1 x 19217 pa5 003, water pump mech seal, £45.52, a, £45.52
4 x 45342 vm0 003, wheel cyl boot, £2.49, a, £9.96
1 x 91357 964 006, brake o ring, £2.49, a, £2.49
2 x 45133 ma3 006, brake boot seal, £2.91, a, £5.82
1 x 54214 vm0 000, gear shift lever boot, £3.00, n/a, £3.00
1 x 45203 mg3016, pin plug, £2.91, n/a, £2.91
4 x 91351 vm0 003, brake o ring, £2.08, a, £8.32
3 x 91313 pe9 003, steering column seal, £2.08, n/a, £6.24
2 x 94305 603 61, spring pin, £1.66, a, £3.32
2 x 83507 ha8 000, glove box lid lever, £9.54, (2 left!), £19.08
4 x 90501 he0 000, steering column shim washer, £2.49, n/a, £9.96
3 x 47144 vm0 770, handbrake lever rubber tip, £4.00, n/a, £12.00
2 x 80132 vm0 000, lower rubber mat, £30.00, n/a, £60.00
1 x 17950 he0 000, choke cable comp, £25.00, n/a, £25.00
1 x 17910 he0 000, throttle cable comp, £25.00, n/a, £25.00
1 x 93500 040 120g, screw, £1.00, a, £1.00
3 x 91509 hc0 000, fender bolt, £2.50, a, £7.50
1 x 16210 he0 000, carb insulator manifold, £41.00, n/a, £41.00
8 x 90504 he0 000, front panel washer collar, £2.50, n/a, £20.00
1 x 51380 he0 670, l,f, upper wishbone susp arm, £146.30, n/a, £146.30
2 x 22210 he0 670, fixed drive face comp, £224.22, n/a, £448.44
2 x 22220 he0 000, moveable drive face comp , £177.00, a, £354.00
2 x 70110 he0 000za, roof panel, £93.00, n/a, £186.00
1 x 19034 he0 670za, radiator grille plastic, £48.00, n/a, £48.00
1 x 62550 he0 000za, front panel, £37.00, n/a, £37.00
2 x 22102 he0 000, Honda drive belt, £85.00, n/a, £170.00
1 x 52390 he0 000, r,r, upper wishbone arm, £173.00, n/a, £173.00
1 x 52100 he0 000, r,r, knuckle assy, £347.00, n/a, £347.00
3 x 18332 430 700, exhaust spring, £4.50, a, £13.50
3 x 80101 he0 000, fender bracket, £9.00, n/a, £27.00
16 x 91077 hb9 672, spherical wishbone bearing, £15.00, a, £240.00
1 x 18358 ha2 000, exhaust ring, £4.14, a, £4.14
1 x 18352 ha2 010, exhaust ring , £4.14, a, £4.14
1 x 28464 950 003, pull start plastic nut, £2.50, n/a, £2.50
1 x 43360 he0 006, parking brake arm, £38.00, n/a, £38.00
6 x 52350 he0 010, lower rear arm assy, £50.00, n/a, £300.00
2 x 51410 he0 003, front shock absorber, £172.00, n/a, £344.00
2 x 50400 ml4 000, end cap, £3.80, a, £7.60
4 x 33744 331 770, reflector base, £2.90, a, £11.60
1 x 33742 hb9 641, reflector orange, £12.00, a, £12.00
2 x 33741 hb9 641, reflector red, £13.25, a, £26.50
1 x 35357 he0 000, parking brake spring, £2.00, n/a, £2.00
1 x 43211 he0 006, parking brake spring , £2.00, n/a, £2.00
4 x 33122 he0 003, head light grille, £20.00, n/a, £80.00
2 x 94305 201 41, spring pin fender, £1.00, a, £2.00
2 x 90320 hb9 000, spring nut, £1.00, a, £2.00
1 x 30410 he0 018, comp CDI (Capacitor Discharge Ignition) unit, £81.00, n/a, £81.00
1 x 30510 kj2 405, ignition coil, £54.00, a, £54.00
1 x 061a0 he0 t00, gasket set, £68.00, n/a, £68.00
1 x 12201 he0 670, cylinder head, £348.00, n/a, £348.00
1 x 12101 he0 670, cylinder, "b", £490.38, n/a, £490.38
1 x 91008 he0 000, bearing, £15.70, n/a, £15.70
1 x 91203 he0 004, oil seal, £7.00, a, £7.00
1 x 43120 he0 316, rear brake pad kit, £102.21, n/a, £102.21
1 x 43455 he0 003, parking brake cable, £20.00, n/a, £20.00
1 x 42300 he0 013, rear axle driveshaft comp, £585.56, n/a, £585.56
1 x 42200 he0 013, rear axle driveshaft comp , £585.56, n/a, £585.56
2 x 83500 he0 010za, r, side panel fender, £139.00, n/a, £278.00
1 x 83600 he0 010za, l, side panel fender , £139.00, n/a, £139.00
1 x 80100 he0 010za, r, rear fender, £163.87, n/a, £163.87
1 x 80110 he0 010za, l, rear fender , £163.87, n/a, £163.87
1 x 61100 he0 010za, r, front fender , £161.80, n/a, £161.80
1 x 61110 he0 010za, l, front fender, £188.29, n/a, £188.29
1 x 80200 he0 010za, floor foot tub, £535.90, n/a, £535.90
1 x 77200 he0 003za, seat comp, £468.86, n/a, £468.86
plus four (two of each) tie rod ends.
the total uk Honda list price for all this comes to around £9240!!!!!! (just to give you an idea!, not necessarily what I want for each part!)
PostPosted: Wed Jan 08, 2014 10:23 am
Nice list of parts. I can only dream of having some of that stuff. I'm surprised pilot pete has not scooped it all up.
1 British pound is equal to 1.64 USA dollar, so 9240 x 1.64 = $15,153.60. That's a lota beans boys. Plus shipping to the USA.
That much will buy ya 3 pilots.
I still wish I had the money to blow on em.
PostPosted: Wed Jan 08, 2014 11:27 am
I spoke to pilotpete, he already has all the stuff so wasn't that much use to him,
if someone wants the lot id take quite a bit less than $15000!!!!!!!!
PostPosted: Wed Jan 08, 2014 1:05 pm
just for the heck of it PM me your best price.
PostPosted: Wed Jan 15, 2014 9:29 pm
I would like to purchase the following (plus some other parts as well):
Is there a number I can call you at so we can make it happen?
Barry (509) 4680-8730
PostPosted: Wed Jan 15, 2014 9:30 pm
Oops - Corrected phone number (509) 468-8730
PostPosted: Wed Jan 15, 2014 10:36 pm
I would like the Parking brake cable 43455-HEO-003 if the whole lot does not sell. Doug
PostPosted: Thu Jan 16, 2014 6:38 pm
Would like to buy the right front fender. PM or call me. 253-209-9627
PostPosted: Mon Jan 20, 2014 1:31 am
I'm interested in the 43360-HE0-006 Brake arm, and do you have the "80202-HE0-000ZA" COVER, STEERING COLUMN CENTER?
Please PM
PostPosted: Sat Jan 25, 2014 4:16 pm
Hello. I am interested in buying the following: 2 of 52395heo003 (rear ball joints), 2 of 88110heo003(mirrors), 1 of 16210heo020 (carb insulator manifold) and 2 of 80101heo000(rear fender brackets). Unless you already sold the lot. Please PM me or call me (818)5686137. Thank you.
PostPosted: Tue Feb 18, 2014 9:08 am
here's an updated list of the new genuine Honda parts I have left.
here are the list of parts that I still have for sale, looking from left to right, first is the quantity I have, then Honda part number, brief description, U.K list price per item, availability from Honda (a or n/a), then the price I want per item (so for example if I have two of the items I want twice the price listed.)
1 x 52395 he0 003, ball joint r,r, upper, £39.87, n/a, £60
1 x 91313 pe9 003, steering column seal, £2.08, n/a, £2
2 x 94305 603 61, spring pin, £1.66, a, £1
2 x 83507 ha8 000, glove box lid lever, £9.54, (2 left!), £10
1 x 17950 he0 000, choke cable comp, £25.00, n/a, £30
3 x 91509 hc0 000, fender bolt, £2.50, a, £2
8 x 90504 he0 000, front panel washer collar, £2.50, n/a, £2.50
2 x 22220 he0 000, moveable drive face comp , £177.00, a, £300 per pair (a pair is, one fixed and one moveable face)
1 x 52100 he0 000, r,r, knuckle assy, £347.00, n/a, £320
3 x 18332 430 700, exhaust spring, £4.50, a, £5
2 x 80101 he0 000, fender bracket, £9.00, n/a, £20
8 x 91077 hb9 672, spherical wishbone bearing, £15.00, a, £12
2 x 51410 he0 003, front shock absorber, £172.00, n/a, £165 (£300 for the pair)
2 x 94305 201 41, spring pin fender, £1.00, a, £1
2 x 90320 hb9 000, spring nut, £1.00, a, £1
1 x 30510 kj2 405, ignition coil, £54.00, a, £30
1 x 12101 he0 670, cylinder, "b", £490.38, n/a, £625 (for the cylinder barrel and head as a pair)
1 x 91203 ks6 004, oil seal, £7.00, a, £7
1 x 42200 he0 013, rear axle driveshaft comp , £585.56, n/a, £500
PostPosted: Tue Mar 18, 2014 1:17 pm
Hi there,
I'm interested in a new right front fender if anyone has one laying around. I know they are tough to find so any help is appecciated.
PostPosted: Thu Mar 27, 2014 7:48 am
hi , sorry my plastics are all sold now.
Registered users: Baidu [Spider], Becerra, Google [Bot]
