It is currently Fri May 16, 2025 8:10 am
PostPosted: Sun Jan 19, 2014 3:12 pm
Hi, I'm a long time lurker here - Learned everything that I know about this machine here!
I've has a really nice FL350 for about 3 years - My 12 year old loves it and it keeps him safe as in he tends to wreck anything without a cage and himself.
The FL350 must be nearly or all original and is in great shape - all original fenders and plastic there and NOT broken! definitely always stored indoors, runs great and ALMOST always starts right up.
The only issue that it has is very intermittent and has NEVER stranded us, but there is a lightly intermittent no spark situation that occurs - A light tap and jiggle or the coil / CDI (Capacitor Discharge Ignition) unit area does the trick and it is weird because it only happens at startup every once in a while - the machine does not die while running?? I've checked all of the wires, etc for short / breaks but can't find it. I know its any easy fix for someone more hands on but I just am not that guy.
I'm in Ventura County, CA and am interested in selling it to a good home for a fair price. Make me an educated, informed offer and come and pick it up.
The registration is current and the CA title is in my name and clear.
I'm happy to take calls, email or text but not sure where to put my number yet?
PostPosted: Sat Feb 01, 2014 12:07 am
hey how much for it?
PostPosted: Sat Feb 01, 2014 12:13 am
No price means FREE.....today and today only! :-)
PostPosted: Sat Feb 01, 2014 12:20 am
lol im on the next plane lol
PostPosted: Thu Feb 06, 2014 3:20 am
wonder what the CDI (Capacitor Discharge Ignition) issue is
PostPosted: Thu Feb 06, 2014 11:12 am
Reads like a bad connection or a wire in the harness that perhaps is broken inside? I have seen where a small nick in wire insulation at the factory years later corrodes inside the harness and the wires jacket until it breaks in two, I say at the factory because of where the damaged wire is located inside the factory wrapped harness.
Next time spark is lost would be the time to pin point the bad spot, pull the plug and wiggle one item at a time until you get spark don't just shake 10' of harness or 20 different locations then check again for spark, track down the exact location, process of elimination is the key to most successful electrical problem fixes.
PostPosted: Sun Mar 16, 2014 3:16 pm
Hi, Thanks for the advice - I've pulled the wiring harness apart twice (each time no spark) tracked each wire to no avail. It always starts working fine as soon as I get into it and honestly, other than the obvious fact that an intermittent issue can strand you, it has not been a problem.
I didn't list a price as I was asking for someone with some knowledge to make me a fair offer. I would like to make some room and would like to sell it for $2500 as it is all stock and been cared for well but anything close should work.
PostPosted: Mon Mar 17, 2014 1:10 pm
Clean machine, would likely get close to 3000 up here in the midwest.
PostPosted: Wed May 14, 2014 7:39 pm
Sold
PostPosted: Wed May 14, 2014 8:50 pm
Dang, sold your 12 yr. olds buggy! That's just mean!
PostPosted: Sat Jan 17, 2015 10:08 pm
Do you still have it ? What's the number or email ?
PostPosted: Mon Jan 19, 2015 11:55 am
bajalobster wrote:
Sold
looks like its sold ?
