duwem wrote:
Given the dimensions of a Ody/pilot, the foot pedals would not work, but they could have designed the chassis to have them.
Steering wheel seems to work fine in a straight line, its just at full lock when you need to move your hand to actuate the throttle that's annoying. And there is extra added complexity of parts to make the brakes work through there.
And I know some will say man up, but would have been nice to have a little softer steering ratio/larger wheel (or a rack and pinion) to make steering easier.
I will only speak for the Pilot since that is the one I have the most experience using, if you have complaints about how hard a stock Pilot steering is then yeah I gotta say man up, start working out, either your weak and need to add some muscle to your upper body or you have a ATV Racing bumps steer kit installed OR you have the wrong off set after market rims on the front and your fighting the leverage ratio that is working against the driver.
The only complaints I have ever had about the Pilot or Odyssey hand controls is riding so much both hands end up being one big blister
With a rack and pinion you have to use force to drive the steering both ways, with the stock steering it will almost drive back straight from a turn (self center) on its own a stock Pilot steers much easier I would say at least 2x easier than a Pilot with a rack and pinion installed, I have driven all 3 types of steering, stock, rack and pinion, bump steer kit from ATV Racing, STOCK is the best/easiest by far.
Once you increase the length of the A arms on a Pilot past a certain point your forced to change to either a rack and pinion or a drag link setup for your steering, adding complexity, weight, more force required by the driver, maintenance, cost etc.
With all the women I have seen drive Pilots I cant remember a single one of them complaining about the steering on a Pilot OR the hand controls.
If you go to the RZR board you see guys by the dozens crying about how hard a RZR-S is to steer and spending 800-1000 bux on power steering, same deal have seen many women driving a RZR-S and I always ask if they think it needs power steering so far the answer has been NO from all of them.
If your Pilot is all stock including the rims I would go through the entire steering system and ensure nothing is rusted up or worn out you might have something bad that is making yours hard to steer.
