It is currently Sat May 17, 2025 10:07 am
 Post subject: Pilot Fuel Sensor
PostPosted: Mon Mar 24, 2014 3:25 pm
Does anyone have a Pilot FL400 Fuel Sensor for sale?
 Post subject: Re: Pilot Fuel Sensor
PostPosted: Mon Mar 24, 2014 4:43 pm
Search is our friend and how I found the below https://www.google.com/search?q=style+g ... S:official
viewtopic.php?f=1&t=11955&start=0
viewtopic.php?f=4&t=12623&start=0
PostPosted: Mon Mar 24, 2014 6:11 pm
I checked out these sites and did not find the fuel sensor. Honda is out of stock. Does anyone have a used one for sale?
PostPosted: Mon Mar 24, 2014 6:29 pm
Did you bother to READ any of them if your looking for just a new sensor I cant help you you will probably have better luck finding a brand new 57 Chevy that has less than 10 miles on it, if you want to repair your current sensor and save yourself time and money then you might want to read.
PostPosted: Mon Mar 24, 2014 6:31 pm
Have you removed the sensor yet? If not, pull it and make sure the white wire (part of sensor on the inside of the fuel tank) isnt broken or loose at the solder joint, easy fix. Also does the low fuel light stay on or NEVER come on. If it stays on then its more than likely a bad sensor, if it doesnt come on then it could be just a connection, also check both connectors at sensor(on the outside of fuel tank) to make sure its tight on the sensor connectors. If I remember correctly the thermister in the sensor grounds the negative side of the light when its low on fuel.
PostPosted: Tue Mar 25, 2014 6:47 pm
Rebuilding a Pilot and missing fuel sensor
