It is currently Sat May 17, 2025 1:15 am
PostPosted: Tue Jun 10, 2014 4:19 pm
not mine, but i do have a set of 79mm rings not sure if that's the size of this piston or not
http://www.ebay.com/itm/85-HONDA-FL350R ... 326wt_1232
PostPosted: Tue Jun 10, 2014 4:29 pm
can anyone verify if this is the 79mm piston..if so i have a hoserized cylinder on a 78mm bore. i already have 79mm rings.
PostPosted: Tue Jun 10, 2014 4:50 pm
By the part number on the box 13103-VM0-315, that bad boy is an 81mm piston.
PostPosted: Tue Jun 10, 2014 5:01 pm
wow so this a real jem..not sure if it comes with rings or not. i would assume it would. i was just looking at an old thread and my cylinder that i thought would work wont anyway..
so this piston is what everyone wants instead of the wiseco crap..wow who will be the first to jump on it
PostPosted: Tue Jun 10, 2014 5:47 pm
Problem is Fully, the piston is just an expensive paper weight without Honda OEM rings. Wiesco rings won't work.
