It is currently Sat May 17, 2025 1:15 am
 Post subject: 79 mm rings
PostPosted: Fri Jun 20, 2014 4:31 am
Hello all. Im looking for rings for the 79mm (.50 os) post recall piston for my FL350. The part # is 13013-vmo-681. If anyone has them or can help me locate these i would be very grateful. I'm in the process of doing the top end and would like to get back on the trails asap!
 Post subject: Re: 79 mm rings
PostPosted: Fri Jun 20, 2014 8:54 am
Before you give up on finding rings research what other OEM engines used a 79mm piston then see if they also used the ART pistons the rings should be the same?
PostPosted: Sat Jun 21, 2014 12:50 pm
Pm sent
