It is currently Sat May 17, 2025 1:12 am
PostPosted: Wed Jul 09, 2014 11:18 am
Essentially I need everything including and to the right of #27
All I have is #14 but nothing else.
http://www.partzilla.com/parts/search/H ... parts.html
Price shipped to 30066 please.
PostPosted: Wed Jul 09, 2014 3:15 pm
So order them - the only thing not available is the arm#16.
Honda is still selling 15,21,23,24,27,and 30. :-)
RandMan or pilotpete may help you out on 16.
you want me to buy them for you and list them on ebay as discontinued at triple the price? :-)
PostPosted: Wed Jul 09, 2014 4:25 pm
As rmesser said.....
Order what you can through your local dealer which leaves you needing just the arm #16.
Order #16 the Pilot arm from Pilot Pete. He has them available for a pilot but they will also fit the Odyssey.
Now if you don't want to go that route, here is a link I posted for a replacement part for item #16
viewtopic.php?f=1&t=14366
If you go this route, I highly suggest using a return spring due to the shorter length of the arm. You will also need to order item #15 because the one that comes from the YFZ450 has a reversed screw because it is used on the right side of the quad where as the Ody brake system is on the left side.
PostPosted: Wed Jul 09, 2014 8:16 pm
Unfortunately there is really no "one stop shop" for out Pilot or Odyssey parts anymore since OdysseySalvage shut doors. Partzilla is where I would start to get the "available" parts then forum....
