It is currently Fri May 16, 2025 6:51 pm
 Post subject: Oil Change
PostPosted: Fri Aug 15, 2014 9:04 pm
What kind of Engine oil bottom end? And how much do you fill it? I see the oil check, do you poor till it comes out? If you chage the oil on the axle half how do you refill?
 Post subject: Re: Oil Change
PostPosted: Fri Aug 15, 2014 9:18 pm
sorry i didnt put this in tech stuff.
PostPosted: Fri Aug 15, 2014 10:01 pm
What Engine? fl350? pilot?, when you say BOTTOM END do you mean the BALANCER?
The PILOT balancer oil capacity is .21 quarts at disassembly and .17 quarts at draining.
Use 10w-40 4-stroke MOTORCYCLE oil not automobile oil.
"If you change the oil on the axle half how much do you refill?" I have no idea what you are talking about.
Get a service manual, you will need one, when I got my pilot project last month the first thing I bought was a manual.
Bob -:: ::-:
PostPosted: Fri Aug 15, 2014 11:13 pm
Bob -:: ::-:
THE PILOT
lol sorry i do need a manual. Theres 2 oil checks one in front one in the back. My ? is does the front half feed the rear half bottom end , cases!! BALANCER?
PostPosted: Sat Aug 16, 2014 1:01 am
Bob -:: ::-:
THE PILOT
One is the balancer and one is the transmission. They fill two different areas and each have their check bolts
-Jason
PostPosted: Sat Aug 16, 2014 1:10 am
Bob -:: ::-:
THE PILOT
-Jason
thank you do they use the same fluid?
PostPosted: Sat Aug 16, 2014 1:15 am
Bob -:: ::-:
THE PILOT
-Jason
Yes, that is correct!!! That 10-40 Bob was talking about, made by honda if you wanted to get that.....10-40 4 stroke motorcycle oil
-Jason
PostPosted: Sat Aug 16, 2014 1:16 am
Get yourself a manual too :-) It's a life saver, espically if your new to this.
PostPosted: Sat Aug 16, 2014 1:49 am
Bob -:: ::-:
THE PILOT
Please take some pictures of what you are talking about, the only oil in the Engine is in the balancer, there is NO oil in the bottom end, the transmission is seperate. from the Engine, there is no oil lines going between them.
Your description of FRONT half and REAR half have me confused :shock:
Bob -:: ::-:
PostPosted: Sat Aug 16, 2014 6:27 am
Sometimes after a bad meal I wish I had cooling lines to my rear :-)
