It is currently Fri May 16, 2025 7:00 pm
PostPosted: Wed Sep 10, 2014 8:15 pm
Long time lurker, first time poster. You guys are a wealth of information! Due to a lack of riding and lack of someone to ride with, I am thinking about selling my Odyssey. I am in New Hampshire and these things are pretty rare in the Northeast I just have no idea where to price it without giving it away but not overpricing it. POST UPDATED WITH PICS IN NEW POSTS! Here is some information on it:
1985 FL350R with a 1995 Polaris 440 fan swap done right (out of a 440 sport, parts are widely available). Jetted right with a factory pipe and D and D silencer. Does not overheat with the 440. Could be put back to stock it someone wanted to.
Clutching is great with a newer belt
New front brakes, bearings and seals. Rear brake works well.
Lights (hi and low and tail) work. Factory mirrors. Factory Honda tach (not hooked up)
Transmission shifts smoothly
No play in the drive shafts or U joints (have two extra axles shaft stubs and an extra axle)
No play in the ball joints up front
Stock shocks but they don't feel clapped out
Rear tires are newer with knobbies still on them. Fronts are a little older but in good condition. All hold air and don't bleed down.
No rear fenders. Tub is cracked but has a metal footbed with factory traction mats. Cosmetically it has dings and dents as any one that was ridden does but could be cleaned up nice if wanted.
Also have the factory air cooling fins (red ones that tried to solve the overheating problems, none now with the 440!), factory tank with locking cap, fuel pump, no rust in tank, spotless, factory airbox with airhose.
Just trying to get an idea of price. There is a completely stock one in town for $3000. That is the only one I have seen in a long time.
Any help would be great, thanks in advance!
Chris
PostPosted: Wed Sep 10, 2014 8:19 pm
Where in NH are you?
PostPosted: Wed Sep 10, 2014 8:23 pm
I am in Sanbornton, NH in the Lakes Region. About one and a half hours from Boston.
PostPosted: Wed Sep 10, 2014 8:41 pm
My advice would be to remove the tach and the tach wiring harness and sell it separate from the FL350 or offer to throw it in to seal the deal.
Lets see some pics.
PostPosted: Wed Sep 10, 2014 9:02 pm
Thanks fr the advice Hoser! I know its one of things what will someone pay but whats the tach with harness worth? I will grab some pics tomorrow during the daylight.
PostPosted: Thu Sep 11, 2014 12:46 am
the tach can sell for whatever someone is willing to pay. seems to me that they go for around $300, but the last one i saw was a pilot tach. If you have the factory wire harness and brackets ect to hook the tach up to an FL350 that is a big plus!
PostPosted: Thu Sep 11, 2014 10:47 am
It might be a Pilot tach but it is cleanly mounted on the FL350 with factory brackets and wiring harness. I will grab some pictures tonight. Thanks!
PostPosted: Thu Sep 11, 2014 5:57 pm
they are both the same tach
just different wiring harness
PostPosted: Thu Sep 11, 2014 9:01 pm
Hopefully these pics work. Obviously the front wheels were off when they were taken (I was doing brake work) I couldn't shrink them so here are the links:
[image]Image[/image]
PostPosted: Thu Sep 11, 2014 9:05 pm
PostPosted: Thu Sep 11, 2014 9:08 pm
PostPosted: Thu Sep 11, 2014 9:10 pm
So now with the pictures, any idea what I should ask for it?
Also, the wiring harness and tach are definitely factory for the FL350R so I will be selling that...I will try here first in case anyone wants it.
Thanks for all of the help!
Chris
