It is currently Fri May 16, 2025 6:52 pm
 Post subject: Must see restored fl350
PostPosted: Fri Sep 12, 2014 10:25 am
This 1985 honda odyssey fl350 was restored from the ground up and I have a TON money into it. I'll start with the chassis, perfectly straight frame, sand blasted and powder coated, works shocks on all four corners, ALL of the j-arms were sent to atv racing in Phoenix to have new ball joints installed that are replaceable which was one huge downfall on the fl350 because they would get very sloppy. The front end is tight, Douglas wheels with Kendall bear claw tires. The master cylinder is in good working condition and looks brand new which is very rare, new brake pads all around, custom front bumper, seat has been re-upholstered and is PERFECT. All the wiring has been gone through and re wrapped. Now for the motor (( Internal Combustion Engine ? )) and trans, transmission shifts perfectly and leaks NO OIL, motor (( Internal Combustion Engine ? )) has been rebuilt from the crankcase to the piston, cleaned up all casting flaws, new crank bearings and seals, weisco piston with Teflon coated skirt and ceramic coated dome, liquid cooled head, yamaha banshee radiator with billed aluminum overflow tank , 35mm pwk air striker carb, dg pipe with quiet silencer, modified air box dual snorkel, uni filter oiled properly, 102c comet clutch with brand new belt, brand new fuel pump fuel filter and all hoses are plumbed properly. I have tons of work into this machine so if your interested come take a look. Consider reasonable trades (no cars), or cash
PostPosted: Fri Sep 12, 2014 3:06 pm
Oh yea Call dan for more info 815 793 9545
