It is currently Thu May 15, 2025 10:51 am
PostPosted: Thu Jul 30, 2015 6:00 pm
1985 Honda Odyssey FL350 - $1200 (Cresskill)
1985 Honda Odyssey FL350. Has not run in years, been in storage. Adult owned. Engine is free. will need some work of course. Was not beat on.
http://newjersey.craigslist.org/mcy/5148284083.html
PostPosted: Tue Aug 11, 2015 9:49 pm
Hey i bought this one...was a 4 and a half hour drive there and back...odyssey was all stock...no rips in seat ...sitting for15 years....so he says......anyway got it home and looked good....tried to start...starter worked good...check spark plug and gunk like brown gunk keeps fouling out the plug...got it to start almost twice...but keeps splashing up some gunk...figured it may have been wd40 or something....so i gave up and pulled the motor (( Internal Combustion Engine ? ))...it was filled with aweful gunk buildup.....so the rings are stuck in the piston...so i figure i can soak it in liquid wrench for a couple of days and get them to pop out...cylinder walls look good...i am gonna split the cases and thoroughly clean everything....would love some stock rings...but i wouldn't mind boring it out and send to someone that knows what they are doing
PostPosted: Wed Aug 12, 2015 6:12 am
jaylow wrote:
Hey i bought this one...was a 4 and a half hour drive there and back...odyssey was all stock...no rips in seat ...sitting for15 years....so he says......anyway got it home and looked good....tried to start...starter worked good...check spark plug and gunk like brown gunk keeps fouling out the plug...got it to start almost twice...but keeps splashing up some gunk...figured it may have been wd40 or something....so i gave up and pulled the motor (( Internal Combustion Engine ? )) (( Internal Combustion Engine ? ))...it was filled with aweful gunk buildup.....so the rings are stuck in the piston...so i figure i can soak it in liquid wrench for a couple of days and get them to pop out...cylinder walls look good...i am gonna split the cases and thoroughly clean everything....would love some stock rings...but i wouldn't mind boring it out and send to someone that knows what they are doing
Can you post some pictures of what your seeing? Sounds like the bottom end had a bunch of water inside.
PostPosted: Wed Aug 12, 2015 8:16 pm
Yea i had a bunch of water in the bottom end...changing all bearings in bottom end crank looks good...
