It is currently Thu May 15, 2025 10:29 am
PostPosted: Fri Aug 28, 2015 8:45 pm
I have not been on here in a while because I have been having a lot of problems with my Kidneys. Any thing you buy right now will help with medical costs. I still have a lot of NOS parts left.
(2) top end gasket sets of OEM Gaskets containing:2 ex. springs 18332-430-700 ex. pipe gasket 18352-HA2-010 ex. ring 18358-HA2-000 ex. joint 18291-HE0-010 head gasket 12251-HE0-000 reed gasket 14011-Heo-003 base gasket 12191-HE0-000 $115 each
OEM base gasket 12191-HE0-000 and OEM reed gasket (out of package) 14011-HE0-003 $20
New set of afastcar's black hoses (6) hose clamps 19506-KS6-700 (4) plastic clips 50314-HE0-003 also a used small plastic clip in good shape $55 SOLD
Air Intake kit containing Intake manifold 16210-HE0-000 elbow 17253-HE0-000 clamp 16223-KA3-740 screw 93500-050250A clamp 95018-82250 clamp 95018-62250 uni airbox filter NU-41143T $275
Engine Kit containing seals 91201-402-015 19217-PA5-003 91201-965-000 91203-HE0-003 91203-KS6-004
bearings 91001-KA4-003 91002-HE0-003 and Koyo Japan replacements for 91032-HE0-005 and 91033-HE0-005
studs (4) 11-92900-10045-3B dowels (2) 94301-12200 (2) 95701-399-000 (replaces discontinued 90701-HE0-000) (2) 94301-10160 (2) 94301-08140 (2) 94301-14200 OEM gasket set 061A0-HE0-T00 custom made balancer magnetic drain bolt Total $400 SOLD
master cylinder diaphragm 45520-MG7-006 $7
shift lever boot 54214-VM0-000 $40
fuel tank drain bolt 92800-12000 + (2) crush washers $7
roll bar nut cap 71928-HE0-000 (used in very good shape) $7
Rear brake pads 43120-HE0-316 and pin $40
driven spring cover 22237-HE0-000 $25
rebuild seal kit for one rear shock + x-rings to replace o-rings in two shocks for better sealing $22
(2) tuff belts $37 ea. SOLD
(1) FL400 balancer magnetic drain plugs $10 ea.
(6) FL350 transmission magnetic drain bolt $10 ea.
(6) 6mm copper Honda OEM sealing washer for water pump balancer oil check bolt and cylinder coolant drain for $1 ea. with any other item
(8) 8mm Honda OEM sealing washer for trans drain bolt $1 ea. with any other item
Used 89 OEM silencer in great shape including silver heat shield MAKE OFFER plus shipping. Can take pics if needed.
'90 fuel catch tank and joint used in very good shape 17517-HE0-670 and 16121-HE0-670 $40
Misc. OEM used hardware includes some shoulder bolts for plastic $10
Trans filler hose $5 with other items because of shipping cost
If I don't contact you on here you could email me at masracingproducts@yahoo.com
PostPosted: Sat Aug 29, 2015 11:23 pm
My daughter is trying to help me with this because my wife is in the hospital. I am so so sorry for not keeping up to date with what is sold.
