It is currently Thu May 15, 2025 4:07 am
PostPosted: Mon Feb 15, 2016 11:53 am
Hi, wondering if anyone knows a part number of a fuel filter for a FL350 that clips into the stock location. Also what you guys run for fuel line and clamps?
Thanks,
PostPosted: Mon Feb 15, 2016 2:38 pm
FRAM G4168 or Hastings GF97 if you can find one or its equivalent. Check your local Autozone/NAPA/etc.
More info: viewtopic.php?f=64&t=9724
I think this might be the simplest way to buy: http://www.ebay.com/itm/Fuel-Filter-Has ... HC&vxp=mtr
Search for the other x-refs and you may find one $1 cheaper.
Make sure you buy fuel line, not air line, not cheapo clear line, etc. Needs to be the right material otherwise its prone to hardening and/or breaking down. Something clear or semi-tranparent is nice so you can SEE the fuel and any air bubbles. The NAPA up the road form me sells 3-4 different sizes of fuel line, all of it is a slight yellow colored transparent tube.
PostPosted: Mon Feb 15, 2016 3:52 pm
Napa makes one exact replica I am not home right now but I know I posted here at one time. It looks exactly like OEM.
PostPosted: Mon Feb 15, 2016 4:34 pm
Is this fuel line any good? Currently I have some black and red hoses on there that i should replace.
http://www.ebay.com/itm/Honda-odyssey-f ... WU&vxp=mtr
Is the Napa filter any different from the Fram or the Hastings?
PostPosted: Tue Feb 16, 2016 4:36 pm
I used the Honda FL250 fuel filter. Fits in the holder and everything. Not sure why the FL350 is discontined but the FL250 one is readily available. I searched everywhere for the fram one but was told fram discontined it
