It is currently Wed May 14, 2025 3:02 pm
PostPosted: Fri Dec 02, 2016 5:37 pm
im looking into reproducing the factory airbox lid. these would probably be a short run as i don't think there is enough interest to spend a ton of money on getting an injection mold made. that will also keep the price on the high side. unless interest is high for both styles, ill probably only make 1 style.
who would be interested in a dual hose airbox lid?
who would be interested in a single hose airbox lid? just like oem?
PostPosted: Fri Dec 02, 2016 7:02 pm
Make one like the old Klem Research lid.
PostPosted: Fri Dec 02, 2016 7:07 pm
I believe he's referring to the pilot
PostPosted: Fri Dec 02, 2016 7:21 pm
correct. i was talking about the pilot. i would have to have one of the klem airbox lids in order to copy it. or make my own design. but i was not thinking of doing them for the FL350R. but i could if there was enough interest.
PostPosted: Fri Dec 02, 2016 8:02 pm
On my 350s I have changed out the screws with longer all thread and added spacers under the lid. This spaces it up about 3/4" and allows air to flow in from all directions. It seems to work well and it can be easily be changed back to stock. But I also don't ride through water.
PostPosted: Fri Dec 02, 2016 9:19 pm
I'd take 5 of them but I'd have to see them first. Still waiting on the parking brake cable from your post 5 months ago. Whatever happened to that?
PostPosted: Sat Dec 03, 2016 2:11 am
Duneit,
ill shoot you a pm.
PostPosted: Thu Dec 08, 2016 1:02 pm
I'd be interested in a dual hose.
PostPosted: Thu Dec 08, 2016 2:28 pm
once i figure out how much they will be, ill see if it can be done then. i was thinking of drawing up one with dual hoses but having one hole blocked off and it could be cut out for dual snorkel use, or leave it blocked off for single hose use.
this will be a work in process for a while, so its going to be at least a couple months before i have anything in hand.
