It is currently Thu Mar 28, 2024 10:22 am
 Post subject: Salsbury clutch
PostPosted: Fri May 05, 2017 2:40 am
Anybody got a used original Salsbury clutch from an FL350 they want to get rid off ??
How much you want ??
I need a few pieces for mine to get it back together. One arm is worn right through, one roller is damaged and the uhmw sliders inside are worn bad.
 Post subject: Re: Salsbury clutch
PostPosted: Fri May 05, 2017 12:11 pm
Buy yourself a 94c or a 102c. Much better clutches than the Salibury.
You will also want to check the plastic inner sleeve for wear.
PostPosted: Fri May 05, 2017 2:12 pm
Well I totally agree with you there Rand, but I hate having parts around that are still good and useable if you just put some time and effort into fixing it.
I also have a powerbloc that was on one of the machines when I bought it, but the offset is wrong and it eats belts up. The offset is off by about 3/4". Don't know what it would have been off of.
Registered users: Bing [Bot], Duneit, eseymour72, Google [Bot], Lanix, Q, wyeeoddy
