It is currently Fri Apr 26, 2024 3:22 pm
PostPosted: Thu Oct 19, 2017 3:49 pm
for pic i have a album on IMGUR there is 96 pics
will not ship in less you do all work as i'm not a shipper and i do not do shipping quotes
will be listing it on ebay for 2500 will do 20% on here for cash sale
there is a lot of parts i'm not going to start splitting it up one person sale only
then they can split it up
Located in Michigan North of grand rapids 49321
https://imgur.com/a/JrZdc
3 seats with frames
1 seat frame
5 matching pairs of front tires with wheels mounted
1 tire and wheel front
2 front wheels rims
4 matching pairs of rear tires with wheels mounted
2 rear tires
2 rear wheels
1 top roll cage nice with head net
1 set of J arms & spindles brake hub assembly 1R 1L
14 J arms
2 lower left
4 upper left
4 upper right
4 lower right
6 spindle and brake hub assembly 3 right 3 left
3 front brake drums
1 spindle Right
1 front brake backing plate
3 trailing arm left side
2 trailing arm Right side
2 complete sets trailing arm with axle hubs & pivot perch 1 left 1 right
3 rear axle bearing hubs
6 rear pivot perch
3 transmission 1 good pull out 1 good for parts bad upper bearing 1 needs upper seal and bearing
2 rear brake disc
1 complete Engine at 81 mm bore comet duster clutch stater and pull rope used running ?
4 wiring harasses
3 steering wheel columns
4 belt guards long
2 belt guards short
6 head lights & 2 brackets
2 pull cords housings
5 pairs of front bumper clamps
1 set of upper and lower air boxes
1 battery box and extra parts
2 tool boxes
3 E brake handles
4 sets of Engine and transmission brackets
2 mis trans brackets
4 front shocks
3 steering shafts
2 complete sets pivot and tie rods
1 steering pivot
5 tie rods
5 roll cage roof lids
1 set 5 point seat belt
1 lot drive belts 1 intake hose 1 roll bar pad
2 staters 1 complete 1 for parts
2 front brake lines and hoses
4 front plastic ignition switch covers
4 side cover plastic for above
1 great no rust gas tank and brackets
1 lot of rubber mats for foot tub
2 sets of air duct side shelds
3 open gasket sets not complete
3 shifters with cables for parts
4 head nets & 1 extra hoop
2 skid plates
2 dg pipes
1 dg muffler cut
1 set of ex400? A arms off 4 wheeler
1 set of a-arms and spindle dics brakes and shocks wheel bolt patern fits fl350 front wheels
PostPosted: Thu Oct 19, 2017 6:15 pm
What's happening speed ??
You getting out of the oddy thing ??
PostPosted: Thu Oct 19, 2017 6:29 pm
too much stuff out with the old in with the new
PostPosted: Thu Oct 19, 2017 6:34 pm
Bet you had some people panicking LOL.
Good to here.
At my house, anything I have not used in 2yrs goes to the dump. UNLESS it's oddy parts or nuts n bolts.
PostPosted: Thu Oct 19, 2017 6:40 pm
I need one front left tire gasket and the muffler bearing oil, How much is shipping to NL?
Cool Pics on your FB, I thought you were in AZ for some reason.
Good luck.
PostPosted: Wed Nov 01, 2017 1:46 am
Speedchaser - where in Michigan are you located?
PostPosted: Thu Nov 02, 2017 10:50 am
49321 north of grand rapids
PostPosted: Mon Nov 13, 2017 5:45 am
Are you selling everything as a big package or can we buy things individually?
PostPosted: Mon Nov 13, 2017 8:23 am
speedchaser wrote:
i'm not going to start spitting it up
***Splitting
PostPosted: Mon Nov 13, 2017 10:29 am
CurtisR401 wrote:
***Splitting
Thanks Bump ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Bump
PostPosted: Sun Jan 07, 2018 1:50 am
WHAT DID YOU STILL HAVE LEFT?
Registered users: Bing [Bot], BrandonFL, Garemie, Google [Bot]
