It is currently Tue May 13, 2025 7:12 pm
 Post subject: Need parts help
PostPosted: Wed Jul 24, 2019 6:32 pm
Need parts to complete project or for sale ay the right price
I don't know what's missing has good compression but missing most of the bolts holding drivetrain in
 Post subject: Re: Need parts help
PostPosted: Wed Jul 24, 2019 8:54 pm
Welcome new guy.
That thing is going to cost a hell of a lot of money to get running reliably.
No offence but that thing is not worth very much. It has been involved in a big crash.
The top cage is bent bad and it looks like someone used a torch to try to straighten it.
It's damaged similar to what mine was and I bet the frame is also bent.
Just my opinion.
PostPosted: Thu Jul 25, 2019 12:19 am
Let us know what you need. Hopefully someone can help you out. There's hoards of parts out there (a handful of people own like 95% of the left over parts) and getting this thing running could be a fun project, and a great way of keeping another FL350 from rotting away in someone's back yard.
Welcome to the site.
PostPosted: Thu Jul 25, 2019 8:46 am
The picture doesn't tell us much about the drivetrain. It appears the driven clutch may be missing??? Missing brake caliper/rotor? Give us a good clear picture of the drive portion on the left side. I hope this odyssey only cost you a few hundred dollars cause its what I would consider a parts-only machine.
PostPosted: Fri Jul 26, 2019 12:46 am
A friend has a nice one I just figured I could piece this together but it seems like it will take alot of work.
I have airbox, carb, expansion pipe, rear caliper, tank.
I need a rear rotor, all bolts for motor (( Internal Combustion Engine ? ))/trans.
I CV is loose.
I'm not sure if bent or not I just bolted it together haphazardly haphazardly. Thanks for the input I had alot of fun with a fl250 years back.
