It is currently Wed May 14, 2025 2:43 pm
 Post subject: Decal Application
PostPosted: Sun May 28, 2006 4:34 am
Step 1 This is how i apply my decals,hope this helps you out, Regards Baz.
File comment: Make sure plastic fender is smooth & clean with Meth-Spirits. position decal & mask tape half only, do not use cellophane tape TOO sticky.
File comment: Peel back backing,& cut off at middle of free end, Lightly spray with water mist,& drop of detergent to both mating surfaces. This helps in positioning.
File comment: Using soft cloth slowly push down & along from middle to end, to push out any air bubbles. Repeat at other end.
PostPosted: Mon Mar 15, 2010 9:37 pm
bump
