It is currently Wed May 14, 2025 11:21 am
PostPosted: Wed Jan 13, 2010 6:33 am
Running, in machine right now. Will be putting in 583rotax. Fuel tank will also be in way, as will electronics for motor (( Internal Combustion Engine ? )). Starter is DOA.
I can leave it in the machine, so you can test run it before you hand over the cash.
I also have a 350 in pieces, jug had got siezed up, score in bore. (should have all parts there) starter condition unkown .
Located in Delaware, North end.
If you have a bad itch, 302.753.8318 thanks
After checking evilbay pricing, $450 gets pull out with CDI (Capacitor Discharge Ignition), gas tank, clutch, ect.
Other motor (( Internal Combustion Engine ? )), all parts, clutch, case, head and bore $150
PostPosted: Thu Jan 14, 2010 11:38 am
installed pricing on original. first come first serve.
PostPosted: Thu Jan 14, 2010 4:45 pm
I will take it all if you have a video of it running and can ship to Texas.
I need one for my 350.
Registered users: eseymour72, Google [Bot], Lanix, socalgii, wyeeoddy
