It is currently Wed May 14, 2025 2:52 pm
PostPosted: Fri Mar 12, 2010 5:13 pm
any help would be greatly appreciated I am new to this and this is my first odyssey i pulled it out of the weeds and got it running and now all's i need is a master cylinder to ride it
PostPosted: Fri Mar 12, 2010 6:09 pm
Whats wrong with the current master cylinder?
Both are bad?
PostPosted: Fri Mar 12, 2010 7:15 pm
Welcome to the board, here is a rebuild kit for the master cylinder on ebay.
Got any pictures of you odyssey?
http://cgi.ebay.com/ebaymotors/FRONT-RE ... ccessories
Bob ::-:
 Post subject: MASTER CYLNDER
PostPosted: Fri Mar 12, 2010 11:54 pm
Can you get the rebuild kit from honda ?
 Post subject: Re: MASTER CYLNDER
PostPosted: Sat Mar 13, 2010 1:07 am
he can.. but he said his pistons were frozen SOLID.. i think he needs a new one
PostPosted: Sat Mar 13, 2010 9:10 am
Pull the clips (snap rings) from the top of the master cylinder and pull the shafts out...
Mine were frozen solid as well and the rubber was all gummed up inside the master cylinder shaft...
the gummed up fliud could not move through the lines and it was locked soild... pull them...
Mine are perfect now... any questions let me know...hell send it to me in MA with the rebuild kit and I will do it for you
Regards G.O.
PostPosted: Sat Mar 13, 2010 11:49 am
viewtopic.php?t=5874&highlight=
PostPosted: Sun Mar 14, 2010 2:37 am
Regards G.O.
+1 to that advice, one of mine was really nasty too, but it cleaned up just fine with lots of elbow grease.
