It is currently Wed May 14, 2025 6:31 pm
PostPosted: Mon Apr 19, 2010 6:44 pm
For sale is a set of Honda FL350 Odyssey stock wheels and tires. The rims need a good cleaning and have some dings and surface rust. The front tires are Carlisle AT 22X8-10, they have about 85% tread left, both hold air and are in great shape. The rear tires are two off-brands size 22X11-10, they have about 75% tread left, one of the tires holds air and is in good condition with no weather cracking, the other has weather cracking and is leaking air around the bead, the rim bead is not bent so I think its the tire. If you need more info let me know. $200 for the set. I also checked on shipping. Both front tires/wheels, packaged together, will be $40 and both rear tires/wheels, packaged together, will be $60 so total for shipping will be $100, this is for UPS Ground. I priced shipping to the furthest point from me in the 48 contigious states, so shipping might be a little less depending on where you are. I will give a refund for the difference. I can take PayPal but would rather have a Postal money order. Thanks for checking them out!
