It is currently Thu May 15, 2025 10:35 am
PostPosted: Fri Nov 05, 2010 4:06 pm
I need someone to help me out here.
I need one of the rubber thingies the battery box sits in.
71905-HE0-000 Pad, Fr. Cross Pipe
#25
http://www.servicehonda.com/hard%20part ... 20page.htm
Without one of these things the battery box wiggles around and eventually breaks the mount on the box. :shock: :shock:
PostPosted: Fri Nov 05, 2010 4:33 pm
none around that i know of - looks like you'll need to find one used or try your local hardware store. since that rubber piece is a friction fit you may be able to find somehting that will work. maybe a rubber gromet will work.
PostPosted: Fri Nov 05, 2010 6:32 pm
I ran into the same problem with mine. I ended up cutting out the bottom of the battery tray and remaking it with some 1/8" flat stock and bent it up to hold the battery good and tight so it wouldn't move around. Added a piece of rubber to the part that hinges and holds the battery in place on top. So far all has been good.
PostPosted: Sat Nov 06, 2010 3:21 pm
update
I was able to use the radiator rubber mount off a old basket case frame. It appears to be the same thing :-)
thanks for the replies
